ActiveLayer 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 817| 评论: 0|原作者: admin|来自: AutoCAD
指定活动图层。
object.ActiveLayer
类别: 文档
此属性应用于的对象。
只读:不
类型:图层
当前处于活动状态的图层。
创建新对象时,将放置在活动图层上。若要更改现有对象所在的图层,请使用该对象的属性。Layer
要创建新图层,请使用以下方法。Add
要更改图层的可见性或其他属性,请参阅对象。Layer
Sub Example_ActiveLayer()
    ' This example returns the current layer
    ' and then adds a new layer.
    ' Finally, it returns the layer to the previous setting.
    Dim currLayer As AcadLayer
    Dim newLayer As AcadLayer
    ' Return the current layer of the active document
    Set currLayer = ThisDrawing.ActiveLayer
    MsgBox "The current layer is " & currLayer.name, vbInformation, "ActiveLayer Example"
    ' Create a Layer and make it the active layer
    Set newLayer = ThisDrawing.Layers.Add("TestLayer")
    ThisDrawing.ActiveLayer = newLayer
    MsgBox "The new layer is " & newLayer.name, vbInformation, "ActiveLayer Example"
    ' Reset the layer to its previous setting
    ThisDrawing.ActiveLayer = currLayer
    MsgBox "The active layer is reset to " & currLayer.name, vbInformation, "ActiveLayer Example"
(defun c:Example_ActiveLayer()
    ;; This example returns the current layer
    ;; and then adds a new layer.
    ;; Finally, it returns the layer to the previous setting.
    ;; Return the current layer of the active document
    (setq currLayer (vla-get-ActiveLayer doc))
    (alert (strcat "The current layer is " (vla-get-Name currLayer)))
    ;; Create a Layer and make it the active layer
    (setq layers (vla-get-Layers doc))
    (setq newLayer (vla-Add layers "TestLayer"))
    (alert (strcat "The new layer is " (vla-get-Name newLayer)))
    ;; Restore the previous layer
    (alert (strcat "The active layer is restored to " (vla-get-Name currLayer)))
GMT+8, 2026-10-28 00:04
