ActiveDimStyle 属性 (ActiveX)
指定活动尺寸样式。 支持的平台:仅限 Windows 言论此样式将应用于所有新创建的维度。若要更改现有维度的样式,请使用该属性。StyleName 要控制当前文档覆盖的设置,请使用尺寸标注系统变量。有关标注系统变量的列表,请参见 AutoCAD 文档中的“系统变量”。 更改尺寸标注系统变量时,实际上是在为活动尺寸标注样式设置文档覆盖。您不会更改活动尺寸样式本身。若要更改给定尺寸样式的设置,请使用该方法。此方法从文档、维度或其他维度样式复制维度样式配置(包括替代)。CopyFrom 通过 AutoCAD 用户界面创建的尺寸标注是使用活动标注样式以及所有文档覆盖创建的。通过 ActiveX 创建的维度仅使用活动维度样式创建。若要使通过 ActiveX 创建的维度采用文档替代,请使用该方法将维度样式从文档复制到活动维度样式。此过程会将所有现有替代复制到活动维度样式中。CopyFrom 例子VBA: Sub Example_ActiveDimStyle()
' This example returns the current dimension style
' and then sets a new style.
' Finally, it returns the style to the previous setting.
Dim newDimStyle As AcadDimStyle
Dim currDimStyle As AcadDimStyle
' Return current dimension style of active document
Set currDimStyle = ThisDrawing.ActiveDimStyle
MsgBox "The current dimension style is " & currDimStyle.name, vbInformation, "ActiveDimStyle Example"
' Create a dimension style and makes it current
Set newDimStyle = ThisDrawing.DimStyles.Add("TestDimStyle")
ThisDrawing.ActiveDimStyle = newDimStyle ' set current dimension style to newDimStyle
MsgBox "The new dimension style is " & newDimStyle.name, vbInformation, "ActiveDimStyle Example"
' Reset the dimension style to its previous setting
ThisDrawing.ActiveDimStyle = currDimStyle
MsgBox "The dimension style is reset to " & currDimStyle.name, vbInformation, "ActiveDimStyle Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ActiveDimStyle()
;; This example returns the current dimension style
;; and then sets a new style.
;; Finally, it returns the style to the previous setting.
;; Get the current dimension style of the active document
(setq currDimStyle (vla-get-ActiveDimStyle doc))
(alert (strcat "The current dimension style is " (vla-get-Name currDimStyle)))
;; Create a dimension style and make it current
(setq dimStyles (vla-get-DimStyles doc))
(setq newDimStyle (vla-Add dimStyles "TestDimStyle"))
(vla-put-ActiveDimStyle doc newDimStyle) ;; set current dimension style to newDimStyle
(alert (strcat "The new dimension style is " (vla-get-Name newDimStyle)))
;; Restore the previously active dimension style
(vla-put-ActiveDimStyle doc currDimStyle)
(alert (strcat "The dimension style is restored to " (vla-get-Name currDimStyle)))
GMT+8, 2026-10-27 19:52
