Update 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 621| 评论: 0|原作者: admin|来自: AutoCAD
Update 方法 (ActiveX)
将对象更新到绘图屏幕。
object.Update
类型:所有绘图对象、Application、AttributeReference、Dimension、SelectionSet
此方法应用到的对象。
返回值 (RetVal)
无返回值。
Sub Example_Update()
    ' This example creates a line in model space. It displays a
    ' Msgbox immediately before the call to update the line and
    ' again after the call.
    Dim lineObj As AcadLine
    ' Create a Line object in model space
    startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
    endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
    MsgBox "Before the update.", , "Update Example"
    ' The following code draws an object in AutoCAD window
    lineObj.Update
    MsgBox "After the update.", , "Update Example"
    ' The following call updates the entire drawing
    ThisDrawing.Application.Update
(defun c:Example_Update()
    ;; This example creates a line in model space. It displays a
    ;; Msgbox immediately before the call to update the line and
    ;; again after the call.
    ;; Create a Line object in model space
    (setq startPoint (vlax-3d-point 2 2 0)
          endPoint (vlax-3d-point 4 4 0))
    (vla-ZoomAll acadObj)
    (alert "Before the update.")
    ;; The following code draws an object in AutoCAD window
    (vla-Update lineObj)
    (alert "After the update.")
    ;; The following call updates the entire drawing
    (vla-Update acadObj)
GMT+8, 2026-10-27 21:27
