Unload 方法 (ActiveX)
卸载菜单组或外部参照。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论ExternalReference:从图形中卸载对象 (xref) 时,图形打开速度更快,占用的内存更少。未加载的外部参照不显示,并且与外部参照相关的符号表信息不会出现在绘图中。但是,可以通过使用该方法重新加载外部参照来恢复所有信息。ExternalReferenceReload 要卸载外部参照,必须卸载定义外部参照的模块。例如,以下 VBA 代码行卸载存储在变量中的外部引用:xrefInserted ThisDrawing.Blocks.Item(xrefInserted.name).Unload MenuGroup:从图形中卸载菜单组时,对该组内菜单和工具栏的任何引用都将失效。在卸载菜单组之前,请始终删除或设置对要卸载的菜单组中的工具栏和菜单的任何引用。NULL 例子VBA: Sub Example_Unload()
On Error GoTo ERRORHANDLER
' Define external reference to be inserted
Dim xrefHome As AcadBlock
Dim xrefInserted As AcadExternalReference
Dim insertionPnt(0 To 2) As Double
Dim PathName As String
insertionPnt(0) = 1
insertionPnt(1) = 1
insertionPnt(2) = 0
PathName = "c:/AutoCAD/sample/City map.dwg"
' Add the external reference
Set xrefInserted = ThisDrawing.ModelSpace. _
AttachExternalReference(PathName, "XREF_IMAGE", _
insertionPnt, 1, 1, 1, 0, False)
ZoomAll
MsgBox "The external reference is attached."
' Unload the external reference definition
MsgBox "The external reference is unloaded."
Exit Sub
ERRORHANDLER:
MsgBox Err.Description
可视化 LISP: (vl-load-com)
(defun c:Example_Unload()
;; Define external reference to be inserted
(setq insertionPnt (vlax-3d-point 1 1 0)
pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
;; Add the external reference to the block
(setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
(vla-ZoomAll acadObj)
(alert "The external reference is attached.")
;; Unload the external reference definition
(vla-Unload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
(vla-Regen doc :vlax-true)
(alert "The external reference is unloaded.")
;; Reload the external reference definition
(vla-Reload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
(alert "The external reference is reloaded.")
GMT+8, 2026-10-27 22:43
