TranslateCoordinates 方法 (ActiveX)
将点从一个坐标系转换为另一个坐标系。 支持的平台:仅限 Windows 签名VBA: RetVal = object.TranslateCoordinates(Point, FromCoordSystem, ToCoordSystem, Displacement, [OCSNormal])
返回值 (RetVal)类型:变体(双打的三元素阵列) 转换后的 3D 坐标。 言论不能直接将坐标从一个 OCS 转换为另一个 OCS。为此,首先将坐标从一个 OCS 转换为中间坐标系,例如 WCS。然后将该坐标转换为第二个 OCS。 要将 or 对象上的点从 OCS 转换为 WCS,请执行以下操作:PolylineLWPolyline
例子VBA: Sub Example_TranslateCoordinates()
' This example creates a UCS with an origin at 2, 2, 2.
' Next, a point is entered by the user. The WCS and UCS
' coordinates of that point are output in a Msgbox.
' Create a UCS named "New_UCS" in current drawing
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPnt(0 To 2) As Double
Dim yAxisPnt(0 To 2) As Double
' Define the UCS
origin(0) = 2#: origin(1) = 2#: origin(2) = 2#
xAxisPnt(0) = 5#: xAxisPnt(1) = 2#: xAxisPnt(2) = 2#
yAxisPnt(0) = 2#: yAxisPnt(1) = 6#: yAxisPnt(2) = 2#
' Add the UCS to the UserCoordinatesSystems collection
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPnt, yAxisPnt, "New_UCS")
ThisDrawing.ActiveUCS = ucsObj
' Get the active viewport and make sure the UCS icon is on
Dim viewportObj As AcadViewport
Set viewportObj = ThisDrawing.ActiveViewport
viewportObj.UCSIconOn = True
viewportObj.UCSIconAtOrigin = True
ThisDrawing.ActiveViewport = viewportObj
' Have the user enter a point
Dim pointWCS As Variant
pointWCS = ThisDrawing.Utility.GetPoint(, "Enter a point to translate:")
' Translate the point into UCS coordinates
Dim pointUCS As Variant
pointUCS = ThisDrawing.Utility.TranslateCoordinates(pointWCS, acWorld, acUCS, False)
' Display the coordinates of the point
MsgBox "The point has the following coordinates:" & vbCrLf & _
"WCS: " & pointWCS(0) & ", " & pointWCS(1) & ", " & pointWCS(2) & vbCrLf & _
"UCS: " & pointUCS(0) & ", " & pointUCS(1) & ", " & pointUCS(2), , "TranslateCoordinates Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TranslateCoordinates()
;; This example creates a UCS with an origin at 2, 2, 2.
;; Next, a point is entered by the user. The WCS and UCS
;; coordinates of that point are output in a Msgbox.
;; Create a UCS named "New_UCS" in current drawing
;; Define the UCS
(setq origin (vlax-3d-point 2 2 2)
xAxisPnt (vlax-3d-point 5 2 2)
yAxisPnt (vlax-3d-point 2 6 2))
;; Add the UCS to the UserCoordinatesSystems collection
(setq ucsObj (vla-Add (vla-get-UserCoordinateSystems doc) origin xAxisPnt yAxisPnt "New_UCS"))
(vla-put-ActiveUCS doc ucsObj)
;; Get the active viewport and make sure the UCS icon is on
(setq viewportObj (vla-get-ActiveViewport doc))
(vla-put-UCSIconOn viewportObj :vlax-true)
(vla-put-UCSIconAtOrigin viewportObj :vlax-true)
(vla-put-ActiveViewport doc viewportObj)
;; Have the user enter a point
(setq pointWCS (vlax-variant-value (vla-GetPoint (vla-get-Utility doc) nil "\nEnter a point to translate:")))
;; Translate the point into UCS coordinates
(setq pointUCS (vlax-variant-value (vla-TranslateCoordinates (vla-get-Utility doc) pointWCS acWorld acUCS :vlax-false)))
;; Display the coordinates of the point
(alert (strcat "The point has the following coordinates:"
"\nWCS: " (rtos (vlax-safearray-get-element pointWCS 0) 2) ", "
(rtos (vlax-safearray-get-element pointWCS 1) 2) ", "
(rtos (vlax-safearray-get-element pointWCS 2) 2)
"\nUCS: " (rtos (vlax-safearray-get-element pointUCS 0) 2) ", "
(rtos (vlax-safearray-get-element pointUCS 1) 2) ", "
(rtos (vlax-safearray-get-element pointUCS 2) 2)))
GMT+8, 2026-11-11 04:57
