SetDatabase 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 856| 评论: 0|原作者: admin|来自: AutoCAD
将 AutoCAD 数据库与 LayerStateManager 对象相关联。
object.SetDatabase Database
类型:LayerStateManager
此方法应用到的对象。
数据库
访问:仅输入
类型: 数据库
要与对象关联的 Database 对象。LayerStateManager
返回值 (RetVal)
无返回值。
Sub Example_SetDatabase()
    ' The following code saves the color and linetype settings
    ' of the current layer. It uses the SetDatabase method to
    ' associate the current drawing database with the
    ' LayerStateManager object.
    Dim oLSM As AcadLayerStateManager
    ' Access the LayerStateManager object
    Set oLSM = ThisDrawing.Application. _
       GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
    ' Associate the current drawing database with LayerStateManager
    oLSM.SetDatabase ThisDrawing.Database
    oLSM.Save "ColorLinetype", acLsColor + acLsLineType
(defun c:Example_SetDatabase()
    ;; The following code saves the color and linetype settings
    ;; of the current layer. It uses the SetDatabase method to
    ;; associate the current drawing database with the
    ;; LayerStateManager object.
    ;; Access the LayerStateManager object
    (setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
    ;; Associate the current drawing database with LayerStateManager
    (vla-SetDatabase oLSM (vla-get-Database doc))
    (vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
GMT+8, 2026-10-28 01:27
