SetColorBookColor 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 733| 评论: 0|原作者: admin|来自: AutoCAD
指定现有颜色书中的颜色名称。
object.SetColorBookColor BookName, ColorName
类型:AcCmColor
此方法应用到的对象。
书名
访问:仅输入
类型:字符串
颜色书的文件名。
颜色名称
访问:仅输入
类型:字符串
颜色的名称。
返回值 (RetVal)
无返回值。
Sub Example_SetColorBookColor()
    ' This example draws a line and specifies a color name
    ' from an existing color book.
    Dim FirstColor As AcadAcCmColor
    Set FirstColor = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
    FirstColor.SetRGB 80, 100, 244
    Dim line As AcadLine
    startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
    endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
    Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
    ZoomAll
    FirstColor.SetColorBookColor "PANTONE+ Solid Uncoated", "PANTONE Yellow 012 U"
    line.TrueColor = FirstColor
(defun c:Example_SetColorBookColor()
    ;; This example draws a line and specifies a color name
    ;; from an existing color book.
    (setq FirstColor (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB FirstColor 80 100 244)
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    (vla-ZoomAll acadObj)
    (vla-SetColorBookColor FirstColor "PANTONE+ Solid Uncoated" "PANTONE Yellow 012 U")
    (vla-put-TrueColor lineObj FirstColor)
    (vlax-release-object FirstColor)
GMT+8, 2026-10-26 20:41
