Select 方法 (ActiveX)
选择对象并将其放入选择集中,或选择表格中的单元格。 支持的平台:仅限 Windows 签名 - SelectionSetVBA: object.Select Mode [, Point1] [, Point2] [, FilterType, FilterData]
签名 - 表格VBA: object.Select wpt, wvwVec, wvwxvec, wxaper, wyaper, allowOutside, resultRowIndex, resultColumnIndex
返回值 (RetVal)无返回值。 备注 - SelectionSet此方法支持过滤机制。 提供以下选择模式:
有关更多选择模式选项,请参见 、 和 方法。SelectByPolygonSelectAtPointSelectOnScreen 备注 - 表格此函数通过指定点、查看方向和方向来选择表格中的单元格。所选单元格的行和列索引在 resultRowIndex 和 resultColumnIndex 中返回。 例子VBA: Sub Example_Select()
' This example adds members to a selection set, first by crossing and
' then by filtering for circles.
' Create the selection set
Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")
' Add all object to the selection set that lie within a crossing of (28,17,0) and
' (-3.3, -3.6,0)
Dim mode As Integer
Dim corner1(0 To 2) As Double
Dim corner2(0 To 2) As Double
mode = acSelectionSetCrossing
corner1(0) = 28: corner1(1) = 17: corner1(2) = 0
corner2(0) = -3.3: corner2(1) = -3.6: corner2(2) = 0
ssetObj.Select mode, corner1, corner2
' Add all the Circles to the selection set that lie within the crossing of (28,17,0) and
' (-3.3, -3.6,0) by filtering from the current drawing
Dim gpCode(0) As Integer
Dim dataValue(0) As Variant
gpCode(0) = 0
dataValue(0) = "Circle"
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
ssetObj.Select mode, corner1, corner2, groupCode, dataCode
可视化 LISP: (vl-load-com)
(defun c:Example_Select()
;; This example adds members to a selection set, first by crossing and
;; then by filtering for circles.
;; Create the selection set
(setq ssetObj (vla-Add (vla-get-SelectionSets doc) "SSET"))
;; Add all object to the selection set that lie within a crossing of (28,17,0) and
;; (-3.3, -3.6,0)
(setq mode acSelectionSetCrossing
corner1 (vlax-3d-point 28 17 0)
corner2 (vlax-3d-point -3.3 -3.6 0))
(vla-Select ssetObj mode corner1 corner2)
(alert (strcat "Objects selected: " (itoa (vla-get-Count ssetObj))))
(vla-Clear ssetObj)
;; Add all the Circles to the selection set that lie within the crossing of (28,17,0) and
;; (-3.3, -3.6,0) by filtering from the current drawing
(setq gpCode (vlax-make-safearray vlax-vbInteger '(0 . 0)))
(vlax-safearray-put-element gpCode 0 0)
(setq dataValue (vlax-make-safearray vlax-vbVariant '(0 . 0)))
(vlax-safearray-put-element dataValue 0 "Circle")
(vla-Select ssetObj mode corner1 corner2 gpCode dataValue)
(vla-Delete ssetObj)
GMT+8, 2026-10-26 14:27
