Reverse 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 726| 评论: 0|原作者: admin|来自: AutoCAD
反转样条的方向。
object.Reverse
类型:样条曲线
此方法应用到的对象。
返回值 (RetVal)
无返回值。
Sub Example_Reverse()
    ' This example creates a spline in model space.
    ' It then reverses the spline and therefore the
    ' control point data.
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    Dim msg As String
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    GoSub GETPOINTS
    MsgBox "Before the reverse the first control point is " & msg
    ' Reverse the Spline and therefore control point data
    splineObj.Reverse
    ThisDrawing.Regen True
    GoSub GETPOINTS
    MsgBox "After the reverse the first control point is " & msg
    Exit Sub
GETPOINTS:
    msg = ""
    ' Get the coordinates from the first control point again
    Dim count As Integer
    For count = 0 To 2
        msg = msg & splineObj.GetControlPoint(0)(count) & ", "
    Next
    msg = VBA.Left(msg, Len(msg) - 2)
    Return
(defun c:Example_Reverse()
    ;; This example creates a spline in model space.
    ;; It then reverses the spline and therefore the
    ;; control point data.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				                                 5 5 0
				                                 10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Get the coordinates from the first control point again
    (setq msg ""
          count 0)
    (while (>= 2 count)
        (setq msg (strcat msg (rtos (vlax-safearray-get-element (vlax-variant-value (vla-GetControlPoint splineObj 0)) count) 2) ", ")
              count (1+ count)
    (setq msg (vl-string-right-trim ", " msg))
    (alert (strcat "Before the reverse the first control point is " msg))
    ;; Reverse the Spline and therefore control point data
    (vla-Reverse splineObj)
    (vla-Regen doc :vlax-true)
    (setq msg ""
          count 0)
    (while (>= 2 count)
              count (1+ count)
    (alert (strcat "After the reverse the first control point is " msg))
GMT+8, 2026-10-26 15:40
