Replace 方法 (ActiveX)
将字典中的项目替换为给定项目。 支持的平台:仅限 Windows 签名VBA: object.Replace Name, NewObject 返回值 (RetVal)无返回值。 言论例如,以下字典中的“FirstKeyword”:
附加了一个新对象“NewObject”:
例子VBA: Sub Example_Replace()
' This example creates a dictionary and adds
' a custom object to that dictionary. It then
' replaces the object in the dictionary.
Dim dictObj As AcadDictionary
Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
' Load the ObjectARX application that defines the custom object.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the path and name of your ObjectARX application.
ThisDrawing.Application.LoadArx "MyARXApp.dll"
' Create the custom object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As AcadObject
keyName = "OBJ1"
className = "CAsdkDictObject"
Set customObj = dictObj.AddObject(keyName, className)
' Replace the object from the dictionary with a different object
Dim newCustomObject As AcadObject
dictObj.Replace keyName, newCustomObject
可视化 LISP: (vl-load-com)
(defun c:Example_Replace()
;; This example creates a dictionary and adds
;; a custom object to that dictionary. It then
;; replaces the object in the dictionary.
(setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
;; Load the ObjectARX application that defines the custom object.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the path and name of your ObjectARX application.
(vla-LoadArx acadObj "MyARXApp.dll")
;; Create the custom object in the dictionary
(setq keyName "OBJ1")
(setq className "CAsdkDictObject")
(setq customObj (vla-AddObject dictObj keyName className))
;; Replace the object from the dictionary with a different object
(setq newCustomObject (vlax-make-variant))
(vlax-variant-type newCustomObject vlax-vbObject)
(vla-Replace dictObj keyName newCustomObject)
GMT+8, 2026-11-11 04:57
