RenameCellStyle 方法 (ActiveX)
重命名单元格样式。 支持的平台:仅限 Windows 签名VBA: object.RenameCellStyle StringOldName, StringNewName
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_CellStyle()
' the style name and formatting.
Dim dictObj As AcadDictionary
' Create the custom TableStyle object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As IAcadTableStyle
keyName = "NewStyle"
className = "AcDbTableStyle"
Set customObj = dictObj.AddObject(keyName, className)
customObj.Name = "NewStyle"
customObj.Description = "New Style for My Tables"
customObj.CreateCellStyle ("NewTestStyle")
Dim cellTestFormat As String
customObj.SetFormat2 "NewTestStyle", "test format"
customObj.GetFormat2 "NewTestStyle", cellTestFormat
MsgBox "Cell Style Name = " & cellTestFormat
customObj.RenameCellStyle "NewTestStyle", "NewTestStyle2"
customObj.GetFormat2 "NewTestStyle2", cellTestFormat
Dim uniqueStyleName As String
uniqueStyleName = customObj.GetUniqueCellStyleName("testbase")
MsgBox "Cell Style Name = " & uniqueStyleName
If customObj.GetIsCellStyleInUse("testbase") = False Then
MsgBox "That cell style is not being used!"
End If
customObj.CreateCellStyleFromStyle "TestStyleFromStyle", "NewTestStyle2"
customObj.DeleteCellStyle "NewTestStyle2"
Dim numOfStyles As Long
numOfStyles = customObj.NumCellStyles
可视化 LISP: (vl-load-com)
(defun c:Example_CellStyle()
;; the style name and formatting.
(setq dictObj (vla-Item dictionaries "acad_tablestyle"))
;; Create the custom TableStyle object in the dictionary
(setq keyName "NewStyle"
className "AcDbTableStyle")
(setq customObj (vla-AddObject dictObj keyName className))
(vla-put-Name customObj "NewStyle")
(vla-put-Description customObj "New Style for My Tables")
(vla-CreateCellStyle customObj "NewTestStyle")
(setq cellTestFormat "")
(vla-SetFormat2 customObj "NewTestStyle" "test format")
(vla-GetFormat2 customObj "NewTestStyle" 'cellTestFormat)
(alert (strcat "Cell Style Name = " cellTestFormat))
(vla-RenameCellStyle customObj "NewTestStyle" "NewTestStyle2")
(vla-GetFormat2 customObj "NewTestStyle2" 'cellTestFormat)
(setq uniqueStyleName (vla-GetUniqueCellStyleName customObj "testbase"))
(alert (strcat "Cell Style Name = " uniqueStyleName))
(if (= (vla-GetIsCellStyleInUse customObj "testbase") :vlax-false)
(alert "That cell style is not being used!")
(vla-CreateCellStyleFromStyle customObj "TestStyleFromStyle" "NewTestStyle2")
(vla-DeleteCellStyle customObj "NewTestStyle2")
(setq numOfStyles (vla-get-NumCellStyles customObj))
(alert (strcat "Number of Cell Styles = " (itoa numOfStyles)))
GMT+8, 2026-10-28 09:03
