Remove 方法 (ActiveX)
从字典中删除命名对象。 支持的平台:仅限 Windows 言论例如,从以下字典中删除名称为“FirstKeyword”的对象:
在以下字典中搜索结果:
例子VBA: Sub Example_Remove()
' This example creates a dictionary and adds
' a custom object to that dictionary. It then
' removes the object from the dictionary.
Dim dictObj As AcadDictionary
Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
' Load the ObjectARX application that defines the custom object.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the path and name of your ObjectARX Application.
ThisDrawing.Application.LoadArx "MyARXApp.arx"
' Create the custom object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As AcadObject
keyName = "OBJ1"
className = "CAsdkDictObject"
Set customObj = dictObj.AddObject(keyName, className)
' Remove the object from the dictionary using the keyName
dictObj.Remove keyName
可视化 LISP: (vl-load-com)
(defun c:Example_Remove()
;; This example creates a dictionary and adds
;; a custom object to that dictionary. It then
;; removes the object from the dictionary.
(setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
;; Load the ObjectARX application that defines the custom object.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the path and name of your ObjectARX Application.
(vla-LoadArx acadObj "MyARXApp.arx")
;; Create the custom object in the dictionary
(setq keyName "OBJ1")
(setq className "CAsdkDictObject")
(setq customObj (vla-AddObject dictObj keyName className))
;; Remove the object from the dictionary using the keyName
(vla-Remove dictObj keyName)
GMT+8, 2026-10-28 00:01
