Reload 方法 (ActiveX)
重新加载外部参照 (xref)。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论重新加载外部参照时,参照图形的最近保存版本将加载到当前图形中。 例子VBA: Sub Example_Reload()
On Error GoTo ERRORHANDLER
' Define external reference to be inserted
Dim xrefHome As AcadBlock
Dim xrefInserted As AcadExternalReference
Dim insertionPnt(0 To 2) As Double
Dim PathName As String
insertionPnt(0) = 1
insertionPnt(1) = 1
insertionPnt(2) = 0
PathName = "c:/AutoCAD/sample/City map.dwg"
' Add the external reference to the block
Set xrefInserted = ThisDrawing.ModelSpace. _
AttachExternalReference(PathName, "XREF_IMAGE", _
insertionPnt, 1, 1, 1, 0, False)
ZoomAll
MsgBox "The external reference is attached."
' Reload the external reference definition
ThisDrawing.Blocks.Item(xrefInserted.name).Reload
MsgBox "The external reference is reloaded."
Exit Sub
ERRORHANDLER:
MsgBox Err.Description
可视化 LISP: (vl-load-com)
(defun c:Example_Reload()
;; Define external reference to be inserted
(setq insertionPnt (vlax-3d-point 1 1 0)
pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
;; Add the external reference to the block
(setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
(vla-ZoomAll acadObj)
(alert "The external reference is attached.")
;; Unload the external reference definition
(vla-Unload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
(vla-Regen doc :vlax-true)
(alert "The external reference is unloaded.")
;; Reload the external reference definition
(vla-Reload (vla-Item (vla-get-Blocks doc) "XREF_IMAGE"))
(alert "The external reference is reloaded.")
GMT+8, 2026-11-15 12:32
