Prompt 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 776| 评论: 0|原作者: admin|来自: AutoCAD
Prompt 方法 (ActiveX)
在命令行上显示提示符。
object.Prompt Message
类型: 实用程序
此方法应用到的对象。
消息
访问:仅输入
类型:字符串
要显示的提示。
返回值 (RetVal)
无返回值。
Sub Example_Prompt()
    ' This example will use the Utility object to display a prompt to the
    ' AutoCAD command line.  To see the results after running the example,
    ' switch to AutoCAD and look at the command line.
    ThisDrawing.Utility.Prompt "Press any key..."
(defun c:Example_Prompt()
    ;; This example will use the Utility object to display a prompt to the
    ;; AutoCAD command line.  To see the results after running the example,
    ;; switch to AutoCAD and look at the command line.
    (vla-Prompt (vla-get-Utility doc) "Press any key...")
GMT+8, 2026-10-28 00:41
