MergeCells 方法 (ActiveX)
合并表中的单元格。 支持的平台:仅限 Windows 签名VBA: object.MergeCells minRow, maxRow, minCol, maxCol
返回值 (RetVal)无返回值。 言论此方法合并单元格的矩形区域。要合并的单元格总数等于 。(maxRow - minRow + 1) * (maxCol - minCol + 1) 例子VBA: Sub Example_MergeCells()
Dim MyModelSpace As AcadModelSpace
Set MyModelSpace = ThisDrawing.ModelSpace
Dim pt(2) As Double
Dim MyTable As AcadTable
Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
Call MyTable.MergeCells(2, 3, 2, 3)
MsgBox "The cells have been merged appropriately."
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_MergeCells()
(setq pt (vlax-3d-point 0 0 0))
(setq MyTable (vla-AddTable modelSpace pt 5 5 10 30))
(vla-MergeCells MyTable 2 3 2 3)
(alert "The cells have been merged appropriately.")
(vla-ZoomExtents acadObj)
GMT+8, 2026-11-15 13:38
