Import 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 867| 评论: 0|原作者: admin|来自: AutoCAD
Import 方法 (ActiveX)
从文件导入图形或一组保存的图层设置。
签名 - 文档
RetVal = object.Import(FileName, InsertionPoint, ScaleFactor)
类别: 文档
此方法应用到的对象。
文件名
访问:仅输入
类型:字符串
要导入的文件的名称。
插入点
访问:仅输入
类型:变体(双打的三元素阵列)
3D WCS 坐标在当前图形中放置导入文件的位置。
比例因子
访问:仅输入
类型:
用于放置导入文件的比例。
签名 - LayerStateManager
object.Import FileName
类型:LayerStateManager
此方法应用到的对象。
文件名
访问:仅输入
类型:字符串
要从中导入图层设置的文件的名称。
返回值 (RetVal) - 文档
类型:对象
在导入 WMF 文件的情况下,将返回一个对象。在所有其他情况下,返回值为 NULL。BlockReference
返回值 (RetVal) - LayerStateManager
无返回值。
Sub Example_Import()
    ' This example will create a new drawing. Be sure to save
    ' your work and start a new drawing before running this example.
    ' This example creates a circle. It then exports the drawing
    ' to a file called DXFExport.DXF. It then opens a new drawing
    ' and imports the file.
    ' Create the circle for visual representation
    Dim circleObj As AcadCircle
    Dim centerPt(0 To 2) As Double
    Dim radius As Double
    centerPt(0) = 2: centerPt(1) = 2: centerPt(2) = 0
    radius = 1
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
    ZoomAll
    ' Create an empty selection set
    Dim sset As AcadSelectionSet
    Set sset = ThisDrawing.SelectionSets.Add("TEST")
    ' Export the current drawing to the file specified above.
    Dim exportFile As String
    exportFile = "C:\AutoCAD\DXFExport"    ' Adjust path for your system
    ThisDrawing.Export exportFile, "DXF", sset
    ' Open a new drawing
    Dim Acad As AcadApplication
    Dim newdoc As AcadDocument
    Set Acad = ThisDrawing.Application
    Set newdoc = Acad.Documents.Add("acad.dwt")
    ' Define the import
    Dim importFile As String
    Dim InsertPoint(0 To 2) As Double
    Dim scalefactor As Double
    importFile = "C:\AutoCAD\DXFExport.dxf"  ' Adjust path for your system
    InsertPoint(0) = 0#: InsertPoint(1) = 0#: InsertPoint(2) = 0#
    scalefactor = 2#
    ' Import the file
    ThisDrawing.Import importFile, InsertPoint, scalefactor
    ZoomAll
(defun c:Example_Import()
    ;; This example will create a new drawing. Be sure to save
    ;; your work and start a new drawing before running this example.
    ;; This example creates a circle. It then exports the drawing
    ;; to a file called DXFExport.DXF. It then opens a new drawing
    ;; and imports the file.
    ;; Create the circle for visual representation
    (setq centerPt (vlax-3d-point 2 2 0))
    (setq radius 1)
    (setq circleObj (vla-AddCircle modelSpace centerPt radius))
    (vla-ZoomAll acadObj)
    ;; Create an empty selection set
    (setq sset (vla-Add (vla-get-SelectionSets doc) "TEST"))
    ;; Export the current drawing to the file specified above.
    (setq exportFile "C:\\AutoCAD\\DXFExport")    ;; Adjust path for your system
    (vla-Export doc exportFile "DXF" sset)
    ;; Define the import
    (setq insertPoint (vlax-3d-point 0 0 0))
    (setq importFile "C:\\AutoCAD\\DXFExport.dxf"  ;; Adjust path for your system
          scalefactor 2)
    ;; Import the file
    (vla-Import doc importFile insertPoint scalefactor)
    (vla-Delete sset)
GMT+8, 2026-9-12 07:56
