GetWindowToPlot 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 803| 评论: 0|原作者: admin|来自: AutoCAD
获取定义要打印的布局部分的坐标。
object.GetWindowToPlot LowerLeft, UpperRight
类型:布局、PlotConfiguration
此方法应用到的对象。
左下角
访问:仅输出
类型:变体(双精度的双元素数组)
左下角窗口的 X 和 Y 值。
右上
访问:仅输出
类型:变体(双精度的双元素数组)
右上角窗口的 X 和 Y 值。
返回值 (RetVal)
无返回值。
窗口坐标取自原点。
这些值的单位由属性指定。PaperUnits
该属性必须设置为 才能将这些坐标用于绘图。PlotTypeacWindow
Sub Example_GetWindowToPlot()
    ' This example allows the user to define an area in the current layout to plot
    ' and displays a plot preview of the defined area.
    ' * Note: You will have to exit the plot preview
    '  before the VBA example will stop and control will be returned
    Dim point1 As Variant, point2 As Variant
    ' Get first point in window
    point1 = ThisDrawing.Utility.GetPoint(, "Click the lower-left of the window to plot.")
    ReDim Preserve point1(0 To 1)   ' Change this to a 2D array by removing the Z position
    ' Get second point in window
    point2 = ThisDrawing.Utility.GetPoint(, "Click the upper-right of the window to plot.")
    ReDim Preserve point2(0 To 1)   ' Change this to a 2D array by removing the Z position
    ' Send information about window to current layout
    ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2
    ' Read back window information
    ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2
    MsgBox "Press any key to plot the following window:" & vbCrLf & vbCrLf & _
           "Lower Left: " & point1(0) & ", " & point1(1) & vbCrLf & _
           "Upper Right: " & point2(0) & ", " & point2(1)
    ' Make sure the instruction is to plot a view, not some other plot style
    ThisDrawing.ActiveLayout.PlotType = acWindow
    ' Send Plot To Window
    ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3"
    ThisDrawing.Plot.DisplayPlotPreview acFullPreview
(defun c:Example_GetWindowToPlot()
    ;; This example allows the user to define an area in the current layout to plot
    ;; and displays a plot preview of the defined area.
    ;; * Note: You will have to exit the plot preview
    ;;  before the VBA example will stop and control will be returned
    ;; Get first point in window
    (setq point1 (vlax-variant-value (vla-GetPoint (vla-get-Utility doc) nil "Click the lower-left of the window to plot.")))
    ;; Change this to a 2D array by removing the Z position
    (setq pointTemp1 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
    (vlax-safearray-put-element pointTemp1 0 (vlax-safearray-get-element point1 0))
    (vlax-safearray-put-element pointTemp1 1 (vlax-safearray-get-element point1 1))
    ;; Get second point in window
    (setq point2 (vlax-variant-value (vla-GetCorner (vla-get-Utility doc) point1 "Click the upper-right of the window to plot.")))
    (setq pointTemp2 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
    (vlax-safearray-put-element pointTemp2 0 (vlax-safearray-get-element point2 0))
    (vlax-safearray-put-element pointTemp2 1 (vlax-safearray-get-element point2 1))
    ;; Send information about window to current layout
    (vla-SetWindowToPlot (vla-get-ActiveLayout doc) pointTemp1 pointTemp2)
    ;; Read back window information
    (vla-GetWindowToPlot (vla-get-ActiveLayout doc) 'point1 'point2)
    (setq point1 (vlax-safearray->list point1)
	         point2 (vlax-safearray->list point2))
    (alert (strcat "Press any key to plot the following window:"
                   "\nLower Left: " (rtos (nth 0 point1) 2) ", " (rtos (nth 1 point1) 2)
                   "\nUpper Right: " (rtos (nth 0 point2) 2) ", " (rtos (nth 1 point2) 2)))
    ;; Make sure the instruction is to plot a view, not some other plot style
    (vla-put-PlotType (vla-get-ActiveLayout doc) acWindow)
    ;; Send Plot To Window - A plot device must be set before a preview can be created
    (vla-DisplayPlotPreview (vla-get-Plot doc) acFullPreview)
GMT+8, 2026-10-27 14:21
