GetProjectFilePath 方法 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 748| 评论: 0|原作者: admin|来自: AutoCAD
获取 AutoCAD 在其中查找外部参照文件的目录。
RetVal = object.GetProjectFilePath(ProjectName)
类型:PreferencesFiles
此方法应用到的对象。
项目名称
访问:仅输入
类型:字符串
项目的名称。此名称也由 PROJECTNAME 系统变量控制。
返回值 (RetVal)
类型:字符串
AutoCAD 在其中查找外部参考文件的目录。
Sub Example_GetProjectFilePath()
    ' This example finds the current project file information.
    Set preferences = ThisDrawing.Application.preferences
    ' Get the current project file information
    Dim currProjPath As String
    Dim currProjName As Variant
    currProjName = ThisDrawing.GetVariable("PROJECTNAME")
    If currProjName <> "" Then
        currProjPath = preferences.Files.GetProjectFilePath(currProjName)
    End If
    If currProjPath = "" Then
        MsgBox "There is no current project file or path. ", , "GetProjectFilePath Example"
    Else
        MsgBox "The current project file path is: " & currProjPath, , "GetProjectFilePath Example"
    End If
(defun c:Example_GetProjectFilePath()
    ;; This example finds the current project file information.
    ;; Get the current project file information
    (setq currProjName (vlax-variant-value (vla-GetVariable doc "PROJECTNAME")))
    (if (/= currProjName "")
        (progn
            (setq currProjPath (vla-GetProjectFilePath (vla-get-Files preferences) currProjName))
	           (alert (strcat "The current project file path is: " currProjPath))
        (alert "There is no current project file or path.")
GMT+8, 2026-10-27 21:31
