GetPoint 方法 (ActiveX)
获取在AutoCAD中选定的点。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetPoint([Point [, Prompt]])
返回值 (RetVal)类型:变体(双打的三元素阵列) AutoCAD 用户所选点的三维 WCS 坐标。 言论AutoCAD 暂停用户输入点,并将返回值设置为选定点的值。Point 参数指定 WCS 中的相对基点。Prompt 参数指定 AutoCAD 在暂停之前显示的字符串。“点”和“提示”都是可选的。 AutoCAD 用户可以通过以当前单位格式输入坐标来指定点; 将 Point 参数和返回值视为三维点。用户也可以通过在图形屏幕上指定位置来指定该点。如果提供了“点”参数,AutoCAD 将绘制一条从“点”到当前十字准线位置的橡皮筋线。GetPoint 存储在返回值中的点的坐标以 WCS 表示。 如果返回的是关键字而不是点,AutoCAD 将生成错误消息“用户输入关键字”。使用该方法从返回值中获取关键字。GetInput 例子VBA: Sub Example_GetPoint()
' This example returns a point entered by the user.
Dim returnPnt As Variant
' Return a point using a prompt
returnPnt = ThisDrawing.Utility.GetPoint(, "Enter a point: ")
MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2) & vbCrLf & _
"(Enter the next value without prompting.)", , "GetPoint Example"
' Return a point, no prompt
MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2), , "GetPoint Example"
' Return a point using a base point and a prompt
Dim basePnt(0 To 2) As Double
basePnt(0) = 2#: basePnt(1) = 2#: basePnt(2) = 0#
returnPnt = ThisDrawing.Utility.GetPoint(basePnt, "Enter a point: ")
' Create a line from the base point and the last point entered
Dim lineObj As AcadLine
Set lineObj = ThisDrawing.ModelSpace.AddLine(basePnt, returnPnt)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_GetPoint()
;; This example returns a point entered by the user.
;; Return a point using a prompt
(setq returnPnt (vlax-variant-value (vla-GetPoint (vla-get-Utility doc) nil "Enter a point: ")))
(alert (strcat "The WCS of the point is: " (rtos (vlax-safearray-get-element returnPnt 0) 2) ", "
(rtos (vlax-safearray-get-element returnPnt 1) 2) ", "
(rtos (vlax-safearray-get-element returnPnt 2) 2) "\n"
"(Enter the next value without prompting.)"))
;; Return a point, no prompt
(setq returnPnt (vlax-variant-value (vla-GetPoint (vla-get-Utility doc))))
(rtos (vlax-safearray-get-element returnPnt 2) 2)))
;; Return a point using a base point and a prompt
(setq basePnt (vlax-3d-point 2 2 0))
(setq returnPnt (vlax-variant-value (vla-GetPoint (vla-get-Utility doc) basePnt "Enter a point: ")))
;; Create a line from the base point and the last point entered
(setq lineObj (vla-AddLine modelSpace basePnt returnPnt))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-28 19:50
