GetPaperSize 方法 (ActiveX)
获取已配置纸张的宽度和高度。 支持的平台:仅限 Windows 签名VBA: object.GetPaperSize Width, Height
返回值 (RetVal)无返回值。 言论宽度和高度值的单位由属性指定。PaperUnits 若要设置纸张大小,请使用属性。CanonicalMediaName 例子VBA: Sub Example_GetPaperSize()
' This example gets the width and height of the default
' paper size for your system.
Dim PaperWidth As Double
Dim PaperHeight As Double
ThisDrawing.ActiveLayout.GetPaperSize PaperWidth, PaperHeight
MsgBox "The default paper size is " & vbCrLf & _
"Width: " & PaperWidth & vbCrLf & _
"Height: " & PaperHeight
可视化 LISP: (vl-load-com)
(defun c:Example_GetPaperSize()
;; This example gets the width and height of the default
;; paper size for your system.
(vla-GetPaperSize (vla-get-ActiveLayout doc) 'PaperWidth 'PaperHeight)
(alert (strcat "The default paper size is "
"\nWidth: " (rtos PaperWidth 2)
"\nHeight: " (rtos PaperHeight 2)))
GMT+8, 2026-11-11 04:57
