GetKeyword 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 1035| 评论: 0|原作者: admin|来自: AutoCAD
从用户获取关键字字符串。
RetVal = object.GetKeyword([Prompt])
类型: 实用程序
此方法应用到的对象。
提示
访问:仅输入;自选
类型:变体(字符串)
用于提示用户输入的文本。
返回值 (RetVal)
类型:字符串
从用户返回的关键字。
AutoCAD 暂停用户输入关键字,并将返回值设置为输入的关键字。Prompt 参数指定 AutoCAD 在暂停之前显示的字符串。提示是可选的。返回值的最大长度为 511 个字符。
AutoCAD 用户可以从键盘输入关键字。此方法将接受的关键字列表由对该方法的先前调用设置。如果用户输入的字符串未在调用 中指定,AutoCAD 将显示错误消息并重试(如果指定了提示,则重新显示提示)。如果用户未输入任何内容,但按 Enter 键,则返回空字符串 (“”),除非调用也不允许输入。InitializeUserInputInitializeUserInputGetKeywordInitializeUserInputNULL
Sub Example_GetKeyword()
    ' This example uses Getkeyword to return a keyword entered by the user.
    ' InitializeUserInput establishes the valid keywords.
    ' Define the list of valid keywords
    Dim kwordList As String
    kwordList = "Width Height Depth"
    ThisDrawing.Utility.InitializeUserInput 1, kwordList
    ' Prompt the user to input any of the keywords. Return "Width", "Height" or "Depth" in
    ' the returnString variable depending on whether the user input "W", "H" or "D".
    Dim returnString As String
    returnString = ThisDrawing.Utility.GetKeyword(vbLf & "Enter a keyword [Height/Width/Depth]: ")
    MsgBox "You entered " & returnString, , "GetKeyword Example"
(defun c:Example_GetKeyword()
    ;; This example uses Getkeyword to return a keyword entered by the user.
    ;; InitializeUserInput establishes the valid keywords.
    ;; Define the list of valid keywords
    (setq kwordList "Width Height Depth")
    (vla-InitializeUserInput (vla-get-Utility doc) 1 kwordList)
    ;; Prompt the user to input any of the keywords. Return "Width", "Height" or "Depth" in
    ;; the returnString variable depending on whether the user input "W", "H" or "D".
    (setq returnString (vla-GetKeyword (vla-get-Utility doc) "\nEnter a keyword [Height/Width/Depth]: "))
    (alert (strcat "You entered " returnString))
GMT+8, 2026-10-27 21:31
