GetIsMergeAllEnabled 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 722| 评论: 0|原作者: admin|来自: AutoCAD
获取“merge all”属性的值。
RetVal = object.GetIsMergeAllEnabled(StringCellStyle)
类型:TableStyle
此方法应用到的对象。
StringCellStyle
访问:仅输入
类型:字符串
单元格样式名称。
返回值 (RetVal)
类型:布尔
  • True:启用单元格样式“全部合并”属性。
  • False:未启用单元格样式的“全部合并”属性。
Sub Example_EnableMergeAll()
    ' the style cell merging.
    Dim dictObj As AcadDictionary
    ' Create the custom TableStyle object in the dictionary
    Dim keyName As String
    Dim className As String
    Dim customObj As IAcadTableStyle
    keyName = "NewStyle"
    className = "AcDbTableStyle"
    Set customObj = dictObj.AddObject(keyName, className)
    customObj.Name = "NewStyle"
    customObj.Description = "New Style for My Tables"
    customObj.CreateCellStyle "NewTestStyle2"
    customObj.EnableMergeAll "NewTestStyle2", False
    If customObj.GetIsMergeAllEnabled("NewTestStyle2") = False Then
        MsgBox "Merge all is not enabled!"
    End If
(defun c:Example_EnableMergeAll()
    ;; the style cell merging.
    (setq dictObj (vla-Item dictionaries "acad_tablestyle"))
    ;; Create the custom TableStyle object in the dictionary
    (setq keyName "NewStyle"
          className "AcDbTableStyle")
    (setq customObj (vla-AddObject dictObj keyName className))
    (vla-put-Name customObj "NewStyle")
    (vla-put-Description customObj "New Style for My Tables")
    (vla-CreateCellStyle customObj "NewTestStyle2")
    (vla-EnableMergeAll customObj "NewTestStyle2" :vlax-false)
    (if (= (vla-GetIsMergeAllEnabled customObj "NewTestStyle2") :vlax-false)
        (alert "Merge all is not enabled!")
GMT+8, 2026-10-26 18:22
