GetInteger 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 730| 评论: 0|原作者: admin|来自: AutoCAD
从用户获取整数值。
RetVal = object.GetInteger([Prompt])
类型: 实用程序
此方法应用到的对象。
提示
访问:仅输入;自选
类型:变体(字符串)
用于提示用户输入的文本。
返回值 (RetVal)
类型:
用户返回的整数值。
AutoCAD 暂停用户输入整数,并将返回值设置为选定值。Prompt 参数指定 AutoCAD 在暂停之前显示的字符串。提示是可选的。
AutoCAD 用户可以输入 -32,768 到 +32,767 范围内的任何有效(短)整数。
如果返回的是关键字而不是整数,或者用户按 Enter 键而未输入值,则 AutoCAD 将生成错误编号 -2145320928(以及错误消息“用户输入是关键字”)。使用该方法从返回值中获取关键字。GetInput
Sub Example_GetInteger()
    ' This example returns the integer entered by the user.
    Dim returnInt As Integer
    ' Return the value entered by user. A prompt is provided.
    returnInt = ThisDrawing.Utility.GetInteger("Enter an integer: ")
    MsgBox "The integer entered was " & returnInt & vbCrLf & _
           "(Enter the next value without prompting.)", , "GetInteger Example"
    ' Return the value entered by user. No prompt is provided.
    returnInt = ThisDrawing.Utility.GetInteger()
    MsgBox "The integer entered was " & returnInt, , "GetInteger Example"
(defun c:Example_GetInteger()
    ;; This example returns the integer entered by the user.
    ;; Return the value entered by user. A prompt is provided.
    (setq returnInt (vla-GetInteger (vla-get-Utility doc) "Enter an integer: "))
    (alert (strcat "The integer entered was " (itoa returnInt)
                   "\n(Enter the next value without prompting.)"))
    ;; Return the value entered by user. No prompt is provided.
    (setq returnInt (vla-GetInteger (vla-get-Utility doc)))
    (alert (strcat "The integer entered was " (itoa returnInt)))
GMT+8, 2026-9-13 02:44
