GetInput 方法 (ActiveX)
将用户的输入字符串转换为关键字索引。 支持的平台:仅限 Windows 返回值 (RetVal)类型:字符串 指定输入关键字的索引。 言论此方法检索 AutoCAD 用户在调用其中一个用户输入函数( 方法)期间输入的关键字。Get* 关键字的最大长度为 511 个字符(第 512 个字符保留给该字符)。NULL 对的调用是没有意义的,除非它紧随对用户输入函数之一的调用之后,否则将失败。即便如此,只有当用户输入函数返回错误描述“用户输入是关键字”时,调用才会成功。GetInput 无需在调用方法后调用。GetInputGetKeyword 应用程序识别的关键字由对方法的先前调用指定。关键字的解释完全取决于应用程序。关键字不应与AutoCAD命令的名称重复。InitializeUserInput 用户可以缩写关键字,但始终返回在调用中使用原始大写定义的完整关键字,因此应用程序只需对其定义的每个关键字进行一个字符串比较。GetInputInitializeUserInput 例子VBA: Sub Example_GetInput()
' This example prompts for user input of a point. By using the
' InitializeUserInput method to define a keyword list, the example can also
' return keywords entered by the user.
On Error Resume Next
' Define the valid keywords
Dim keywordList As String
keywordList = "Line Circle"
' Call InitializeUserInput to set up the keywords
ThisDrawing.Utility.InitializeUserInput 128, keywordList
' Get the user input
Dim returnPnt As Variant
returnPnt = ThisDrawing.Utility.GetPoint(, vbLf & "Enter a point [Line/Circle]: ")
If Err Then
If StrComp(Err.Description, "User input is a keyword", 1) = 0 Then
' One of the keywords was entered
Dim inputString As String
Err.Clear
inputString = ThisDrawing.Utility.GetInput
MsgBox "You entered the keyword: " & inputString
Else
MsgBox "Error selecting the point: " & Err.Description
Err.Clear
End If
Else
' Display point coordinates
MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2), , "GetInput Example"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_GetInput()
;; This example prompts for user input of a point. By using the
;; InitializeUserInput method to define a keyword list, the example can also
;; return keywords entered by the user.
;; Define the valid keywords
(setq keywordList "Line Circle")
;; Call InitializeUserInput to set up the keywords
(vla-InitializeUserInput (vla-get-Utility doc) 128 keywordList)
;; Get the user input
(setq returnPntOrErr (vl-catch-all-apply 'vla-GetPoint (list (vla-get-Utility doc) nil "Enter a point [Line/Circle]: ")))
(if (= (type returnPntOrErr)'VL-CATCH-ALL-APPLY-ERROR)
(progn
(if (= (vl-catch-all-error-message returnPntOrErr) "Automation Error. User input is a keyword")
(progn
(setq inputString (vla-GetInput (vla-get-Utility doc)))
(alert (strcat "You entered the keyword: " inputString))
(alert "User pressed ESC or unknown input was provided.")
;; Display point coordinates
(progn
(setq returnPnt (vlax-safearray->list (vlax-variant-value returnPntOrErr)))
(alert (strcat "The WCS of the point is: " (rtos (nth 0 returnPnt) 2) ", " (rtos (nth 1 returnPnt) 2) ", " (rtos (nth 2 returnPnt) 2)))
GMT+8, 2026-10-27 19:20
