GetFont 方法 (ActiveX)
获取 TextStyle 字体的定义数据。 支持的平台:仅限 Windows 签名VBA: object.GetFont Typeface, Bold, Italic, CharSet, PitchAndFamily
返回值 (RetVal)无返回值。 言论本部分提供用于此方法的常量的定义。若要使用这些常量,请复制所需的定义,并将其粘贴到应用程序的“声明”部分。可以在 Visual Basic 开发环境随附的文件win32api.txt中找到 Microsoft 中可用的常量的完整列表。 CharSet 参数指定字体的字符集。若要在 VB 或 VBA 应用程序中使用以下常量,请将定义复制到代码的“声明”部分。 Public Const ANSI_CHARSET = 0 Public Const DEFAULT_CHARSET = 1 Public Const SYMBOL_CHARSET = 2 Public Const SHIFTJIS_CHARSET = 128 Public Const OEM_CHARSET = 255 PitchAndFamily 参数指定字体的音高和族值。该值由三种不同设置的组合确定。通过从三个类别中的每一个类别中选择一个设置并使用布尔运算符 OR 组合它们,您可以获得 PitchAndFamily 值。前两个类别需要设置:音高和家庭。第三类是 TrueType 标志,仅在指定 TrueType 字体时使用。 ' Pitch Values Public Const DEFAULT_PITCH = 0 Public Const FIXED_PITCH = 1 Public Const VARIABLE_PITCH = 2 ' Family Values Public Const FF_DONTCARE = 0 ' Don't care or don't know. Public Const FF_ROMAN = 16 ' Variable stroke width, serifed. Public Const FF_SWISS = 32 ' Variable stroke width, sans-serifed. Public Const FF_MODERN = 48 ' Constant stroke width, serifed or sans-serifed. Public Const FF_SCRIPT = 64 ' Cursive, etc. Public Const FF_DECORATIVE = 80 ' Old English, etc. ' TrueType Flag Public Const TMPF_TRUETYPE = &H4 例子VBA: Sub Example_GetFont()
' This example find the font information for the active text style.
Dim typeFace As String
Dim Bold As Boolean
Dim Italic As Boolean
Dim charSet As Long
Dim PitchandFamily As Long
ThisDrawing.ActiveTextStyle.GetFont typeFace, Bold, Italic, charSet, PitchandFamily
MsgBox "The current text style has the following font properties:" & vbCrLf _
& "Typeface: " & typeFace & vbCrLf _
& "Bold: " & Bold & vbCrLf _
& "Italic: " & Italic & vbCrLf _
& "Character set: " & charSet & vbCrLf _
& "Pitch and Family: " & PitchandFamily
可视化 LISP: (vl-load-com)
(defun c:Example_GetFont()
;; This example finds the font information for the active text style.
;; It then changes the font to bold.
(vla-GetFont (vla-get-ActiveTextStyle doc) 'typeFace 'Bold 'Italic 'charSet 'PitchandFamily)
(alert (strcat "The current text style has the following font properties:"
"\nTypeface: " typeFace
"\nBold: " (if (= Bold :vlax-true) "True" "False")
"\nItalic: " (if (= Italic :vlax-true) "True" "False")
"\nCharacter set: " (itoa charSet)
"\nPitch and Family: " (itoa PitchandFamily)))
;; Change the bold property
(setq Bold (if (= Bold :vlax-true) :vlax-false :vlax-true))
(vla-SetFont (vla-get-ActiveTextStyle doc) typeFace Bold Italic charSet PitchandFamily)
;; Reset the font
GMT+8, 2026-10-27 21:23
