GetControlPoint 方法 (ActiveX)
获取控制点在给定索引处的坐标。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetControlPoint(Index)
返回值 (RetVal)类型:变体(双打的三元素阵列) 控制点在给定索引位置的 3D WCS 坐标。 言论控制点通过向样条曲线的一部分添加权重来微调样条定义。 可以使用该属性查询样条曲线中控制点的总数。您可以使用该方法为控制点设置新的坐标位置。您可以使用该方法为控制点设置新权重。NumberOfControlPointsSetControlPointSetWeight 例子VBA: Sub Example_GetControlPoint()
' This example creates a spline object in model space.
' It then finds the coordinates of the first control point
' and changes that value.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
' Display the coordinates of the first control point
Dim controlPoint As Variant
controlPoint = splineObj.GetControlPoint(0)
MsgBox "Control point 1 is at " & controlPoint(0) & ", " & controlPoint(1) & ", " & controlPoint(2), , "GetControlPoint Example"
' Change the coordinate of the first fit point
controlPoint(0) = 0: controlPoint(1) = 3: controlPoint(2) = 0
splineObj.SetControlPoint 0, controlPoint
splineObj.Update
MsgBox "Control point 1 is now at " & controlPoint(0) & ", " & controlPoint(1) & ", " & controlPoint(2), , "GetControlPoint Example"
可视化 LISP: (vl-load-com)
(defun c:Example_GetControlPoint()
;; This example creates a spline object in model space.
;; It then finds the coordinates of the first control point
;; and changes that value.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display the coordinates of the first control point
(setq controlPoint (vlax-safearray->list (vlax-variant-value (vla-GetControlPoint splineObj 0))))
(alert (strcat "Control point 1 is at " (rtos (nth 0 controlPoint) 2) ", " (rtos (nth 1 controlPoint) 2) ", " (rtos (nth 2 controlPoint) 2)))
;; Change the coordinate of the first fit point
(setq controlPoint (vlax-3d-point 0 3 0))
(vla-SetControlPoint splineObj 0 controlPoint)
(vla-Update splineObj)
(alert (strcat "Control point 1 is now at " (rtos (nth 0 controlPoint) 2) ", " (rtos (nth 1 controlPoint) 2) ", " (rtos (nth 2 controlPoint) 2)))
GMT+8, 2026-10-28 00:28
