GetBoundingBox 方法 (ActiveX)
获取包含指定对象的框的两个点。 支持的平台:仅限 Windows 签名VBA: object.GetBoundingBox MinPoint, MaxPoint
返回值 (RetVal)无返回值。 言论拐角以 WCS 坐标返回,框边平行于 WCS X、Y 和 Z 轴。 ![]() 例子VBA: Sub Example_GetBoundingBox()
' This example creates a line in model space. It then finds the
' bounding box for the line and displays the corners of the box.
Dim lineObj As AcadLine
' Create the Line object in model space
startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
ZoomAll
Dim minExt As Variant
Dim maxExt As Variant
' Return the bounding box for the line and return the minimum
' and maximum extents of the box in the minExt and maxExt variables.
lineObj.GetBoundingBox minExt, maxExt
' Print the min and max extents
MsgBox "The extents of the bounding box for the line are:" & vbCrLf _
& "Min Extent: " & minExt(0) & "," & minExt(1) & "," & minExt(2) _
& vbCrLf & "Max Extent: " & maxExt(0) & "," & maxExt(1) & "," & maxExt(2), vbInformation, "GetBoundingBox Example"
可视化 LISP: (vl-load-com)
(defun c:Example_GetBoundingBox()
;; This example creates a line in model space. It then finds the
;; bounding box for the line and displays the corners of the box.
;; Create the Line object in model space
(setq startPoint (vlax-3D-point 2 2 0))
(setq endPoint (vlax-3D-point 4 4 0))
(vla-ZoomAll acadObj)
;; Return the bounding box for the line and return the minimum
;; and maximum extents of the box in the minExt and maxExt variables.
(vla-GetBoundingBox lineObj 'minExt 'maxExt)
(setq minExt (vlax-safearray->list minExt)
maxExt (vlax-safearray->list maxExt))
;; Print the min and max extents
(alert (strcat "The extents of the bounding box for the line are:"
"\nMin Extent: " (rtos (nth 0 minExt) 2) "," (rtos (nth 1 minExt) 2) "," (rtos (nth 2 minExt) 2)
"\nMax Extent: " (rtos (nth 0 maxExt) 2) "," (rtos (nth 1 maxExt) 2) "," (rtos (nth 2 maxExt) 2)))
GMT+8, 2026-10-26 18:17
