GetAttributes 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 635| 评论: 0|原作者: admin|来自: AutoCAD
获取块引用中的属性。
RetVal = object.GetAttributes
类型:BlockReference、ExternalReference、MInsertBlock
此方法应用到的对象。
返回值 (RetVal)
类型:Variant(AttributeReference 对象的数组)
对象的数组。AttributeReference
此方法返回附加到块引用的可编辑属性引用数组。
您只能返回外部参照的常量属性。若要查找外部引用或块引用的常量属性,请使用该方法。GetConstantAttributes
Sub Example_GetAttributes()
    ' This example creates a block. It then adds attributes to that
    ' block. The block is then inserted into the drawing to create
    ' a block reference.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "TESTBLOCK")
    ' Define the attribute definition
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    height = 1#
    mode = acAttributeModeVerify
    prompt = "Attribute Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "Attribute_Tag"
    value = "Attribute Value"
    ' Create the attribute definition object in model space
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "TESTBLOCK", 1#, 1#, 1#, 0)
    ZoomAll
    ' Get the attributes for the block reference
    Dim varAttributes As Variant
    varAttributes = blockRefObj.GetAttributes
    ' Move the attribute tags and values into a string to be displayed in a Msgbox
    Dim strAttributes As String
    Dim I As Integer
    For I = LBound(varAttributes) To UBound(varAttributes)
        strAttributes = strAttributes & vbLf & "  Tag: " & varAttributes(I).TagString & _
                        vbLf & "  Value: " & varAttributes(I).TextString & vbLf & "    "
    Next
    MsgBox "The attributes for blockReference " & blockRefObj.Name & " are: " & strAttributes, , "GetAttributes Example"
    ' Change the value of the attribute
    ' Note: There is no SetAttributes. Once you have the variant array, you have the objects.
    ' Changing them changes the objects in the drawing.
    varAttributes(0).TextString = "NEW VALUE!"
    Dim newvarAttributes As Variant
    newvarAttributes = blockRefObj.GetAttributes
    ' Again, display the tags and values
    strAttributes = ""
    Next
(defun c:Example_GetAttributes()
    ;; This example creates a block. It then adds attributes to that
    ;; block. The block is then inserted into the drawing to create
    ;; a block reference.
    ;; Create the block
    (setq insertionPnt (vlax-3d-point 0 0 0))
    (setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "TESTBLOCK"))
    ;; Define the attribute definition
    (setq attHeight 1
          attMode acAttributeModeVerify
          attPrompt "Attribute Prompt"
          attTag "Attribute_Tag"
          attValue "Attribute Value"
          insertionPoint (vlax-3d-point 5 5 0))
    ;; Create the attribute definition object in model space
    (setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPoint attTag attValue))
    ;; Insert the block
    (setq insertionPnt (vlax-3d-point 2 2 0))
    (setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "TESTBLOCK" 1 1 1 0))
    (vla-ZoomAll acadObj)
    ;; Get the attributes for the block reference
    (setq varAttributes (vlax-variant-value (vla-GetAttributes blockRefObj)))
    ;; Move the attribute tags and values into a string to be displayed in a Msgbox
    (setq strAttributes ""
          I 0)
    (while (>= (vlax-safearray-get-u-bound varAttributes 1) I)
        (setq strAttributes (strcat strAttributes "\n  Tag: " (vla-get-TagString (vlax-safearray-get-element varAttributes I))
                                                  "\n  Value: " (vla-get-TextString (vlax-safearray-get-element varAttributes I)) "\n"))
        (setq I (1+ I))
    (alert (strcat "The attributes for blockReference " (vla-get-Name blockRefObj) " are: " strAttributes))
    ;; Change the value of the attribute
    ;; Note: There is no SetAttributes. Once you have the variant array, you have the objects.
    ;; Changing them changes the objects in the drawing.
    (vla-put-TextString (vlax-safearray-get-element varAttributes 0) "NEW VALUE!")
    (setq newvarAttributes (vlax-variant-value (vla-GetAttributes blockRefObj)))
    ;; Again, display the tags and values
          I 0)
        (setq I (1+ I))
GMT+8, 2026-10-27 15:07
