GenerateUsageData 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 579| 评论: 0|原作者: admin|来自: AutoCAD
生成指定图层是否正在使用的数据。
object.GenerateUsageData
类型: 图层
此方法应用到的对象。
返回值 (RetVal)
无返回值。
Sub Example_GenerateUsageData()
    ' This example provides usage information for the layers
    ' in a drawing
    Dim MyLayers As AcadLayers
    Set MyLayers = ThisDrawing.Layers
    MyLayers.GenerateUsageData
    Dim MyLayerObj As AcadLayer
    For Each MyLayerObj In ThisDrawing.Layers
        MyLayerObj.Description = "Test"
        MsgBox (MyLayerObj.Used)
    Next MyLayerObj
(defun c:Example_GenerateUsageData()
    ;; This example provides usage information for the layers
    ;; in a drawing
    (setq MyLayers (vla-get-Layers doc))
    (vla-GenerateUsageData MyLayers)
    (vlax-for MyLayerObj MyLayers
        (vla-put-Description MyLayerObj "Test")
        (alert (strcat "Layer " (vla-get-Name MyLayerObj) (if (= (vla-get-Used MyLayerObj) :vlax-true) " is used." " is not used.")))
GMT+8, 2026-10-27 21:25
