Float 方法 (ActiveX)
浮动工具栏。 支持的平台:仅限 Windows 签名VBA: object.Float Top, Left, NumberFloatRows
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_Float()
' This example creates a new toolbar called "TestToolbar" and inserts three
' buttons into it. The toolbar is then displayed as a floating toolbar,
' and then as a docked toolbar.
' To remove the toolbar after execution of this macro, use the Customize Menu
' option from the Tools menu.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new toolbar
Dim newToolBar As AcadToolbar
Set newToolBar = currMenuGroup.Toolbars.Add("TestToolbar")
' Add three buttons to the new toolbar.
' All three buttons will have the same macro attached.
Dim newButton1 As AcadToolbarItem
Dim newButton2 As AcadToolbarItem
Dim newButton3 As AcadToolbarItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newButton1 = newToolBar.AddToolbarButton("", "NewButton1", "Open a file.", openMacro)
Set newButton2 = newToolBar.AddToolbarButton("", "NewButton2", "Open a file.", openMacro)
Set newButton3 = newToolBar.AddToolbarButton("", "NewButton3", "Open a file.", openMacro)
' Display the toolbar
newToolBar.Visible = True
' Dock the toolbar to the left of the screen.
newToolBar.Dock acToolbarDockLeft
GoSub QUERYSTATUS
' Float the toolbar
newToolBar.Float 200, 200, 1
GoSub QUERYSTATUS
Exit Sub
QUERYSTATUS:
' Query the toolbar to see if it is docked.
If newToolBar.DockStatus = acToolbarFloating Then
MsgBox "The toolbar is floating."
Else
MsgBox "The toolbar is docked."
End If
Return
可视化 LISP: (vl-load-com)
(defun c:Example_Float()
;; This example creates a new toolbar called "TestToolbar" and inserts three
;; buttons into it. The toolbar is then displayed as a floating toolbar,
;; and then as a docked toolbar.
;; To remove the toolbar after execution of this macro, use the Customize Menu
;; option from the Tools menu.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new toolbar
(setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "TestToolbar"))
;; Add three buttons to the new toolbar.
;; All three buttons will have the same macro attached.
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newButton1 (vla-AddToolbarButton newToolBar "" "NewButton1" "Open a file." openMacro))
(setq newButton2 (vla-AddToolbarButton newToolBar "" "NewButton2" "Open a file." openMacro))
(setq newButton3 (vla-AddToolbarButton newToolBar "" "NewButton3" "Open a file." openMacro))
;; Display the toolbar
(vla-put-Visible newToolBar :vlax-true)
;; Dock the toolbar to the left of the screen.
(vla-Dock newToolBar acToolbarDockLeft)
;; Query the toolbar to see if it is docked.
(if (= (vla-get-DockStatus newToolBar) acToolbarFloating)
(alert "The toolbar is floating.")
(alert "The toolbar is docked.")
;; Float the toolbar
(vla-Float newToolBar 200 200 1)
GMT+8, 2026-10-27 19:20
