FieldCode 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 568| 评论: 0|原作者: admin|来自: AutoCAD
返回包含域代码的文本字符串。
RetVal = object.FieldCode
类型:MText,文本
此方法应用到的对象。
返回值 (RetVal)
类型:字符串
对象的域代码。
Sub Example_FieldCode()
    ' This example creates a text object in model space.
    ' It then returns the field code string for the object.
    Dim textObj As AcadText
    Dim text As String
    Dim height As Double
    ' Define the text object
    text = "%<\AcVar Date \f ""M/d/yyyy""%>%"
    insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(text, insertionPoint, height)
    ZoomAll
    ' Return the current text string for the object
    text = textObj.FieldCode
    MsgBox "The FieldCode for the text object equals: " & text, vbInformation, "FieldCode Example"
(defun c:Example_FieldCode()
    ;; This example creates a text object in model space.
    ;; It then returns the field code string for the object.
    ;; Define the text object
    (setq insertionPoint (vlax-3d-point 2 2 0)
          text "%<\\AcVar Date \\f \"M/d/yyyy\"%>%"
          height 0.5)
    ;; Create the text object in model space
    (setq textObj (vla-AddText modelSpace text insertionPoint height))
    (vla-ZoomAll acadObj)
    ;; Return the current text string for the object
    (setq text (vla-FieldCode textObj))
    (alert (strcat "The FieldCode for the text object equals: " text))
GMT+8, 2026-10-27 22:44
