Explode 方法 (ActiveX)
将复合对象分解为子实体。 支持的平台:仅限 Windows 签名VBA: RetVal = object.Explode
返回值 (RetVal)类型:变体(对象数组) 分解对象的数组。 言论根据要爆炸的复合物体的类型,会出现不同的结果。有关可分解对象及其结果的详细列表,请参见《AutoCAD 命令参考》中的 EXPLODE 命令主题。 您不必为了操纵其组成实体而分解块。所有块定义都有一个 Item 方法,该方法允许您在不分解块定义本身的情况下操作块中的实体。 例子VBA: Sub Example_Explode()
' This example creates a lightweight polyline in model space.
' It then explodes the polyline.
Dim points(0 To 11) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
points(10) = 4: points(11) = 1
' Create a lightweight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
' Set the bulge on one segment to vary the
' type of objects in the polyline
plineObj.SetBulge 3, -0.5
ZoomAll
' Explode the polyline
MsgBox "Explode the polyline?", , "Explode Example"
Dim explodedObjects As Variant
explodedObjects = plineObj.Explode
' Loop through the exploded objects
Dim I As Integer
For I = 0 To UBound(explodedObjects)
explodedObjects(I).Update
MsgBox "Exploded Object " & I & ": " & explodedObjects(I).ObjectName, , "Explode Example"
explodedObjects(I).Color = acByLayer
Next
可视化 LISP: (vl-load-com)
(defun c:Example_Explode()
;; This example creates a lightweight polyline in model space.
;; It then explodes the polyline.
;; Define the 2D polyline points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
(vlax-safearray-fill points '(1 1
1 2
2 2
3 2
4 4
4 1
;; Create a lightweight Polyline object in model space
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-put-Color plineObj acRed)
;; Set the bulge on one segment to vary the
;; type of objects in the polyline
(vla-SetBulge plineObj 3 -0.5)
(vla-ZoomAll acadObj)
;; Explode the polyline
(alert "Explode the polyline?")
(setq explodedObjects (vlax-variant-value (vla-Explode plineObj)))
;; Loop through the exploded objects
(setq I 0)
(while (>= (vlax-safearray-get-u-bound explodedObjects 1) I)
(vla-Update (vlax-safearray-get-element explodedObjects I))
(alert (strcat "Exploded Object " (itoa I) ": " (vla-get-ObjectName (vlax-safearray-get-element explodedObjects I))))
(vla-put-Color (vlax-safearray-get-element explodedObjects I) acByLayer)
(setq I (1+ I))
GMT+8, 2026-10-27 13:31
