Eval 方法 (ActiveX)
计算 VBA 中的表达式。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论此方法允许自动化客户端在当前项目的上下文中执行一行 VBA 代码,而无需创建模块和函数。 例子VBA: Sub Example_Eval()
' This example shows how to can use Eval to run a VBA code fragment
' without having to create a Module or procedure.
Dim VBACode As String
' Create VBA code fragment
VBACode = "MsgBox ""Simple code fragment"""
' Use Eval method to evaluate the small VBA script
Eval VBACode
可视化 LISP: (vl-load-com)
(defun c:Example_Eval()
;; This example shows how to can use Eval to run a VBA code fragment
;; without having to create a Module or procedure.
;; Create VBA code fragment
(setq VBACode "MsgBox \"Simple code fragment\"")
;; Use Eval method to evaluate the small VBA script
(vla-Eval acadObj VBACode)
GMT+8, 2026-10-30 12:00
