EndUndoMark 方法 (ActiveX)
标记操作块的结束。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论此方法允许 AutoCAD 关闭环境,以便将 to 中的操作视为一组操作。StartUndoMarkEndUndoMark 例子VBA: Sub Example_EndUndoMark()
' This example creates a series of lines, each one with an undo marker
' defined for it. After lines are created you can switch to AutoCAD and type
' the Undo command, and only one line at a time will be undone. If StartUndoMark
' call is not made, an undo in AutoCAD will undo all the lines at once.
Dim line As AcadLine
Dim stPnt(0 To 2) As Double
Dim endPnt(0 To 2) As Double
stPnt(0) = 1: stPnt(1) = 2: stPnt(2) = 0
endPnt(0) = 2: stPnt(1) = 1: stPnt(2) = 0
' Create the lines
Dim j As Integer
For j = 0 To 3
ThisDrawing.StartUndoMark
Set line = ThisDrawing.ModelSpace.AddLine(stPnt, endPnt)
stPnt(0) = stPnt(0) + 3
endPnt(0) = endPnt(0) + 3
ThisDrawing.EndUndoMark
Next
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_EndUndoMark()
;; This example creates a series of lines, each one with an undo marker
;; defined for it. After lines are created you can switch to AutoCAD and type
;; the Undo command, and only one line at a time will be undone. If StartUndoMark
;; call is not made, an undo in AutoCAD will undo all the lines at once.
(setq stPnt (vlax-3d-point 1 2 0)
endPnt (vlax-3d-point 2 1 0))
;; Create the lines
(setq j 0)
(while (>= 3 j)
(vla-StartUndoMark doc)
(setq line (vla-AddLine modelSpace stPnt endPnt))
(vlax-safearray-put-element (vlax-variant-value stPnt) 0 (+ (vlax-safearray-get-element (vlax-variant-value stPnt) 0) 3))
(vlax-safearray-put-element (vlax-variant-value endPnt) 0 (+ (vlax-safearray-get-element (vlax-variant-value endPnt) 0) 3))
(setq j (1+ j))
(vla-EndUndoMark doc)
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 21:31
