CreateTypedArray 方法 (ActiveX)
创建一个包含类型化参数数组的变体。 支持的平台:仅限 Windows 签名VBA: object.CreateTypedArray VarArr, Type, Value1, [value2, value3, ...valueN]
返回值 (RetVal)无返回值。 言论生成的变体可以传递到任何接受数字数组作为变体的 AutoCAD 方法或特性中。 此方法只能使用后期绑定编程技术进行访问。若要使用此方法,请将对象定义为 ,而不是 。UtilityObject (Dim myObj As Object)AcadUtility 例子VBA: Sub Example_CreateTypedArray()
' This example creates a spline from variant arrays created
' from doubles using the CreateTypedArray method.
' Note that this method must be late bound. This is done
' by declaring the utility object (utilObj) as Object,
' not as AcadUtility.
Dim splineObj As AcadSpline
' Even though these are arrays, they are declared as variants
Dim startTan As Variant
Dim endTan As Variant
Dim fitPoints As Variant
Dim utilObj As Object ' Late bound object
Set utilObj = ThisDrawing.Utility
' Define the spline.
utilObj.CreateTypedArray startTan, vbDouble, 0.5, 0.5, 0
utilObj.CreateTypedArray endTan, vbDouble, 0.5, 0.5, 0
utilObj.CreateTypedArray fitPoints, vbDouble, 0, 0, 0, 5, 5, 0, 10, 0, 0
' Create the spline
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_CreateTypedArray()
;; This example creates a spline from variant arrays created
;; from doubles using the CreateTypedArray method.
;; Note that this method must be late bound. This is done
;; by declaring the utility object (utilObj) as Object,
;; not as AcadUtility.
(setq utilObj (vla-get-Utility doc))
;; Define the spline.
(vla-CreateTypedArray utilObj 'startTan vlax-vbDouble 0.5 0.5 0)
(vla-CreateTypedArray utilObj 'endTan vlax-vbDouble 0.5 0.5 0)
(vla-CreateTypedArray utilObj 'fitPoints vlax-vbDouble 0 0 0 5 5 0 10 0 0)
;; Create the spline
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
GMT+8, 2026-11-15 14:46
