CopyObjects 方法 (ActiveX)
复制多个对象(深度克隆)。 支持的平台:仅限 Windows 签名VBA: RetVal = object.CopyObjects(Objects [, Owner] [, IDPairs]) 返回值 (RetVal)类型:变体(对象数组) 新创建的重复对象的数组。此数组中仅返回主要对象。有关操作期间发生的情况的详细信息,或者也复制了主对象所拥有的对象列表,请参阅 IDPairs 参数。CopyObjects 言论若要将对象复制到另一个打开的图形,请将 Owner 参数设置为另一个图形的模型空间。 在操作过程中,还将复制 Objects 参数中的主要对象拥有或引用的对象。CopyObjects 注意:不能在同时循环访问集合时执行此方法。迭代将为只读操作打开工作空间,而此方法将尝试执行读写操作。在调用此方法之前,请完成任何迭代。
例子VBA: Sub Example_CopyObjects()
' This example creates a Circle object and uses the CopyObjects
' method to make a copy of the new Circle.
Dim DOC1 As AcadDocument
Dim circleObj1 As AcadCircle, circleObj2 As AcadCircle
Dim circleObj1Copy As AcadCircle, circleObj2Copy As AcadCircle
Dim radius1 As Double, radius2 As Double
Dim radius1Copy As Double, radius2Copy As Double
Dim objCollection(0 To 1) As Object
Dim retObjects As Variant
' Define the Circle object
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
radius1 = 5#: radius2 = 7#
radius1Copy = 1#: radius2Copy = 2#
' Create a new drawing
Set DOC1 = Documents.Add
' Add two circles to the drawing
Set circleObj1 = DOC1.ModelSpace.AddCircle(centerPoint, radius1)
Set circleObj2 = DOC1.ModelSpace.AddCircle(centerPoint, radius2)
' Copy objects
' First put the objects to be copied into a form compatible with CopyObjects
Set objCollection(0) = circleObj1
Set objCollection(1) = circleObj2
' Copy object and get back a collection of the new objects (copies)
retObjects = DOC1.CopyObjects(objCollection)
' Get newly created object and apply new properties to the copies
Set circleObj1Copy = retObjects(0)
Set circleObj2Copy = retObjects(1)
circleObj1Copy.radius = radius1Copy
circleObj2Copy.radius = radius2Copy
MsgBox "Circles copied."
可视化 LISP: (vl-load-com)
(defun c:Example_CopyObjects()
;; This example creates a Circle object and uses the CopyObjects
;; method to make a copy of the new Circle.
;; Load the ObjectDBX library
(if (= acLibImport nil)
(progn
(vlax-import-type-library :tlb-filename "C:\\Program Files\\Common Files\\Autodesk Shared\\axdb20enu.tlb"
:methods-prefix "acdbm-"
:properties-prefix "acdbp-"
:constants-prefix "acdbc-"
(setq acLibImport T)
;; Create a reference to the ObjectDBX object
(setq acdbObj (vlax-create-object "ObjectDBX.AxDbDocument.20"))
;; Open an external drawing file
(acdbm-open acdbObj (findfile ".\\Sample\\VBA\\Tower.dwg"))
;; Add two circles to the drawing
(setq objCollection (vlax-make-safearray vlax-vbObject (cons 0 (- (vla-get-Count (vla-get-ModelSpace acdbObj)) 1)))
count 0)
;; Copy objects
(vlax-for eachObj (vla-get-ModelSpace acdbObj)
(vlax-safearray-put-element objCollection count eachObj)
(setq count (1+ count))
;; Copy object and get back a collection of the new objects (copies)
(setq retObjects (vla-CopyObjects acdbObj objCollection (vla-get-ModelSpace (vla-get-Database doc))))
(vla-ZoomAll acadObj)
(alert "Model space objects copied.")
;; Close the in memory drawing
(vlax-release-object acdbObj)
GMT+8, 2026-10-26 13:00
