Copy 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 984| 评论: 0|原作者: admin|来自: AutoCAD
Copy 方法 (ActiveX)
将给定对象复制到同一位置。
RetVal = object.Copy
类型:所有绘图对象、AttributeReference、尺寸
此方法应用到的对象。
返回值 (RetVal)
新创建的重复对象。
AttributeReference:不应尝试在对象上使用此方法。 对象继承此方法,因为它们是绘图对象之一,但是,对属性参照执行此操作是不可行的。AttributeReferenceAttributeReference
注意:不能在同时循环访问集合时执行此方法。迭代将为只读操作打开工作空间,而此方法将尝试执行读写操作。在调用此方法之前,请完成任何迭代。
Sub Example_Copy()
    ' This example creates a circle and then copies
    ' that circle. The new circle is then moved.
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2#: center(1) = 2#: center(2) = 0#
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    MsgBox "Copy the circle.", , "Copy Example"
    ' Copy the circle
    Dim copyCircleObj As AcadCircle
    Set copyCircleObj = circleObj.Copy()
    ' Define the points that make up the move vector
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    point1(0) = 0: point1(1) = 0: point1(2) = 0
    point2(0) = 2: point2(1) = 0: point2(2) = 0
    MsgBox "Move the copied circle 2 units in the X direction.", , "Copy Example"
    ' Move the circle and color it
    copyCircleObj.Move point1, point2
    ZoomAll
    MsgBox "Move completed.", , "Copy Example"
(defun c:Example_Copy()
    ;; This example creates a circle and then copies
    ;; that circle. The new circle is then moved.
    ;; Create the circle
    (setq center (vlax-3d-point 2 2 0)
          radius 0.5)
    (setq circleObj (vla-AddCircle modelSpace center radius))
    (vla-ZoomAll acadObj)
    (alert "Copy the circle.")
    ;; Copy the circle
    (setq copyCircleObj (vla-Copy circleObj))
    ;; Define the points that make up the move vector
    (setq point1 (vlax-3d-point 0 0 0)
          point2 (vlax-3d-point 2 0 0))
    (alert "Move the copied circle 2 units in the X direction.")
    ;; Move the circle and color it
    (vla-Move copyCircleObj point1 point2)
    (alert "Move completed.")
GMT+8, 2026-10-27 22:02
