Boolean 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 932| 评论: 0|原作者: admin|来自: AutoCAD
在对象与另一个 3DSolid 或 Region 对象之间执行布尔运算(并集、相交或减法)。
object.Boolean(Operation, Object)
类型:3DSolid、区域
此方法应用到的对象。
操作
访问:仅输入
类型:枚举AcBooleanType
  • acUnion:执行联合操作。
  • acIntersection:执行交叉路口操作。
  • acSubtraction:执行减法运算。
访问:仅输入
类型:3DSolid、区域
对其执行操作的对象。
返回值 (RetVal)
无返回值。
第一个对象将作为操作的结果进行修改。
布尔相交前的实体
布尔交集生成的实体
注意:如果操作没有结果,则不会更改第一个对象。例如,在查找两个不相交对象之间的交点时,第一个对象没有变化。
Sub Example_Boolean()
    ' This example creates a box and a cylinder in model space.
    ' It then performs a Boolean operation on the two solids.
    Dim boxObj As Acad3DSolid
    Dim boxLength As Double, boxWidth As Double, boxHeight As Double
    Dim boxCenter(0 To 2) As Double
    boxCenter(0) = 5#: boxCenter(1) = 5#: boxCenter(2) = 0
    boxLength = 10#: boxWidth = 7: boxHeight = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace.AddBox(boxCenter, boxLength, boxWidth, boxHeight)
    ' Define the cylinder
    Dim cylinderObj As Acad3DSolid
    Dim cylinderCenter(0 To 2) As Double
    Dim cylinderRadius As Double
    Dim cylinderHeight As Double
    cylinderCenter(0) = 0#: cylinderCenter(1) = 0#: cylinderCenter(2) = 0#
    cylinderRadius = 5#
    cylinderHeight = 20#
    ' Create the Cylinder (3DSolid) object in model space
    Set cylinderObj = ThisDrawing.ModelSpace.AddCylinder(cylinderCenter, cylinderRadius, cylinderHeight)
    ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
    ' Perform an intersection on the two solids
    MsgBox "Perform an intersection on the two solids.", vbOKOnly, "Boolean Example"
    boxObj.Boolean acIntersection, cylinderObj
    ThisDrawing.Regen True
    MsgBox "Intersection complete.", , "Boolean Example"
(defun c:Example_Boolean()
    ;; This example creates a box and a cylinder in model space.
    ;; It then performs a Boolean operation on the two solids.
    (setq boxCenter (vlax-3d-point 5 5 0)
          boxLength 10
	         boxWidth 7
	         boxHeight 10)
    ;; Create the box (3DSolid) object in model space
    (setq boxObj (vla-AddBox modelSpace boxCenter boxLength boxWidth boxHeight))
    ;; Define the cylinder
    (setq cylinderCenter (vlax-3d-point 0 0 0)
          cylinderRadius 5
          cylinderHeight 20)
    ;; Create the Cylinder (3DSolid) object in model space
    (setq cylinderObj (vla-AddCylinder modelSpace cylinderCenter cylinderRadius cylinderHeight))
    ;; Change the viewing direction of the viewport
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
    ;; Perform an intersection on the two solids
    (alert "Perform an intersection on the two solids.")
    (vla-Boolean boxObj acIntersection cylinderObj)
    (vla-Regen doc :vlax-true)
    (alert "Intersection complete.")
GMT+8, 2026-10-28 04:52
