AuditInfo 方法 (ActiveX)
评估图形的完整性。 支持的平台:仅限 Windows 签名VBA: object.AuditInfo FixError
返回值 (RetVal)无返回值。 言论对于检测到的每个错误,AutoCAD 都会提供错误说明并建议纠正措施。 如果指定 FixError = ,AutoCAD 将尝试修复遇到的任何错误。True 例子VBA: Sub Example_AuditInfo()
' This example has AutoCAD audit
' and fix any problems found
ThisDrawing.AuditInfo True
MsgBox "Auditing has been requested." & vbCrLf & _
"The fix error flag is set to True", , "AuditInfo Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AuditInfo()
;; This example has AutoCAD audit
;; and fix any problems found
(vla-AuditInfo doc :vlax-true)
(alert (strcat "Auditing has been requested."
"\nThe fix error flag is set to True."))
GMT+8, 2026-10-27 13:31
