AttachExternalReference 方法 (ActiveX)
将外部参照 (外部参照) 附着到绘图中。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AttachExternalReference(PathName, Name, InsertionPoint, XScale, YScale, ZScale, Rotation, Overlay [, Password])
言论与对象一样,附加对象也可以嵌套。如果其他人正在编辑要参照的图形,则附加的图形将基于最近保存的版本。BlockExternalReference 如果参照文件丢失或损坏,则其数据不会显示在当前图形中。 例子VBA: Sub Example_AttachExternalReference()
' This example displays all the blocks in the current drawing
' before and after adding an external reference.
' This example uses the "city map.dwg" found in the Sample
' directory. If you do not have this drawing, or if it is
' in a different directory, insert a valid path and file name
' for the PathName variable below.
Dim InsertPoint(0 To 2) As Double
Dim insertedBlock As AcadExternalReference
Dim tempBlock As AcadBlock
Dim msg As String, PathName As String
' Define external reference to be inserted
InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
PathName = "c:\program files\autocad\sample\city map.dwg"
' Display current Block information for this drawing
GoSub ListBlocks
' Add the external reference to the drawing
Set insertedBlock = ThisDrawing.ModelSpace.AttachExternalReference(PathName, "XREF_IMAGE", InsertPoint, 1, 1, 1, 0, False)
' Display new Block information for this drawing
GoSub ListBlocks
Exit Sub
ListBlocks:
msg = vbCrLf ' Reset message
For Each tempBlock In ThisDrawing.Blocks
msg = msg & tempBlock.name & vbCrLf ' Add Block to list
Next
MsgBox "The current blocks in this drawing are: " & msg
Return
可视化 LISP: (vl-load-com)
(defun c:Example_AttachExternalReference()
;; This example displays all the blocks in the current drawing
;; before and after adding an external reference.
;; This example uses the "STAIR1.dwg" found in the Sample
;; directory. If you do not have this drawing, or if it is
;; in a different directory, insert a valid path and file name
;; for the PathName variable below.
;; Define external reference to be inserted
(setq InsertPoint (vlax-3d-point 1 1 0))
(setq pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
;; Display current Block information for this drawing
(setq msg "")
(vlax-for tempBlock (vla-get-Blocks doc)
(setq msg (strcat msg (vla-get-Name tempBlock) "\n")) ;; Add Block to list
(alert (strcat "The current blocks in this drawing are: " msg))
;; Add the external reference to the drawing
(setq insertedBlock (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" InsertPoint 1 1 1 0 :vlax-false))
(vla-ZoomAll acadObj)
;; Display new Block information for this drawing
(setq msg "")
GMT+8, 2026-10-28 09:04
