AngleToString 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 819| 评论: 0|原作者: admin|来自: AutoCAD
将角度从实数(双精度)值转换为字符串。
RetVal = AngleToString(Angle, Unit, Precision)
类型: 实用程序
此方法应用到的对象。
角度
访问:仅输入
类型:双
作为双精度值的角度。
单位
访问:仅输入
类型:枚举AcAngleUnits
字符串将转换为的单位。
  • acDegrees
  • acDegreeMinuteSeconds
  • acGrads
  • acRadians
精度
访问:仅输入
类型:长
角度的精度。介于 0 和 8 之间的整数。
返回值 (RetVal)
类型:字符串
作为字符串的角度。
Sub Example_AngleToString()
    ' This example converts a radian value to several different
    ' strings representing the value in different units.
    Dim angAsRad As Double
    Dim unit As Integer
    Dim precision As Long
    Dim angAsString As String
    angAsRad = 0.785398163397448
    unit = acDegrees
    precision = 6
    ' Convert the radian value to degrees with a precision of 6
    angAsString = ThisDrawing.Utility.AngleToString(angAsRad, unit, precision)
    MsgBox "0.785398163397448 radians =  " & angAsString & " degrees", , "AngleAsString Example"
    ' Convert the radian value to degrees/Minutes/Seconds with a precision of 6
    unit = acDegreeMinuteSeconds
    MsgBox "0.785398163397448 radians =  " & angAsString, , "AngleAsString Example"
    ' Convert the radian value to grads with a precision of 6
    unit = acGrads
(defun c:Example_AngleToString()
    ;; This example converts a radian value to several different
    ;; strings representing the value in different units.
    (setq angAsRad 0.785398163397448
          unit acDegrees
          precision 6)
    ;; Convert the radian value to degrees with a precision of 6
    (setq angAsString (vla-AngleToString (vla-get-Utility doc) angAsRad unit precision))
    (alert (strcat "0.785398163397448 radians =  " angAsString))
    ;; Convert the radian value to degrees/Minutes/Seconds with a precision of 6
    (setq unit acDegreeMinuteSeconds)
    ;; Convert the radian value to grads with a precision of 6
    (setq unit acGrads)
GMT+8, 2026-10-26 18:21
