AddTrace 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 785| 评论: 0|原作者: admin|来自: AutoCAD
从点数组创建 Trace 对象。
RetVal = object.AddTrace(PointsArray)
类型:块、模型空间、纸空间
此方法应用到的对象。
点数组
访问:仅输入
类型:变体(双打数组)
指定追踪端点的 3D WCS 坐标数组。
返回值 (RetVal)
类型:跟踪
新创建的对象。Trace
迹线的端点始终位于中心线上,并且始终被切成正方形。AutoCAD 会自动计算连接到相邻迹线段的正确斜角。
当“填充”模式打开时,迹线是实心填充的。当“填充”模式关闭时,仅显示迹线的轮廓。
要设置填充模式,请使用 AutoCAD FILLMODE 系统变量。AutoCAD TRACEWID 系统变量存储用于对象的当前宽度。Trace
Sub Example_AddTrace()
    ' This example creates a trace in model space.
    Dim traceObj As AcadTrace
    Dim tracePts(0 To 11) As Double       ' 4 (3D) points
    ' Define the points of the trace
    tracePts(0) = 1: tracePts(1) = 1: tracePts(2) = 0
    tracePts(3) = 3: tracePts(4) = 3: tracePts(5) = 0
    tracePts(6) = 5: tracePts(7) = 3: tracePts(8) = 0
    tracePts(9) = 5: tracePts(10) = 1: tracePts(11) = 0
    ' Turn on the system variable (FILLMODE)
    ' to fill the outline of the trace
    ThisDrawing.SetVariable "FILLMODE", 1
    ' Create the trace object in model space
    Set traceObj = ThisDrawing.ModelSpace.AddTrace(tracePts)
    ZoomAll
(defun c:Example_AddTrace()
    ;; This example creates a trace in model space.
    ;; Define the points of the trace
    (setq tracePts (vlax-make-safearray vlax-vbDouble '(0 . 11)))
    (vlax-safearray-fill tracePts '(1 1 0
                                    3 3 0
                                    5 3 0
                                    5 1 0
    ;; Turn on the system variable (FILLMODE)
    ;; to fill the outline of the trace
    (vla-SetVariable doc "FILLMODE" 1)
    ;; Create the trace object in model space
    (setq traceObj (vla-AddTrace modelSpace tracePts))
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-27 21:27
