AddSubMenu 方法 (ActiveX)
将子菜单添加到现有菜单中。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddSubMenu(Index, Label)
言论此方法创建一个新对象并将其添加到指定的菜单中。这种特殊类型的对象被分配了 的类型。PopupMenuItemPopupMenuItemacSubmenu 在下面的示例菜单中,“对齐文本”菜单项已插入到“尺寸”菜单的第 17 个索引处。“对齐文本”菜单项的类型为 。示例中的所有其他菜单项类型为 或 。选择“对齐文本”时显示的小型级联菜单是该方法返回的新菜单。它已使用 和 方法进行填充。acSubmenuacMenuItemacMenuSeparatorAddSubmenuAddMenuItemAddSeparator ![]() 例子VBA: Sub Example_AddSubMenu()
' This example creates a new menu called TestMenu and inserts a submenu item
' called NewFile. It then creates a menu item, called open,
' on the submenu.
' The menu is then displayed on the menu bar.
' To remove the menu after execution of this macro, use the Customize Menu
' option from the Tools menu.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new menu
Dim newMenu As AcadPopupMenu
Set newMenu = currMenuGroup.Menus.Add("TestMenu")
' Add the submenu
Dim FileSubMenu As AcadPopupMenu
Set FileSubMenu = newMenu.AddSubMenu("", "NewFile")
' Add a menu item to the sub menu
Dim newMenuItem As AcadPopupMenuItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newMenuItem = FileSubMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
' Display the menu on the menu bar
newMenu.InsertInMenuBar ThisDrawing.Application.MenuBar.count + 1
可视化 LISP: (vl-load-com)
(defun c:Example_AddSubMenu()
;; This example creates a new menu called TestMenu and inserts a submenu item
;; called NewFile. It then creates a menu item, called open,
;; on the submenu.
;; The menu is then displayed on the menu bar.
;; To remove the menu after execution of this macro, use the Customize Menu
;; option from the Tools menu.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new menu
(setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
;; Add the submenu
(setq FileSubMenu (vla-AddSubMenu newMenu "" "NewFile"))
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newMenuItem (vla-AddMenuItem FileSubMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
;; Display the menu on the menu bar
(vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
;; Display the menu bar
(vla-SetVariable doc "MENUBAR" 1)
GMT+8, 2026-10-29 00:06
