AddSphere 方法 (ActiveX)
创建给定中心和半径的球体。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddSphere(Center, Radius) 言论没有其他评论。 例子VBA: Sub Example_AddSphere()
' This example creates a sphere in model space.
Dim sphereObj As Acad3DSolid
Dim radius As Double
centerPoint(0) = 5#: centerPoint(1) = 5#: centerPoint(2) = 0#
radius = 5#
Set sphereObj = ThisDrawing.ModelSpace.AddSphere(centerPoint, radius)
' Change the viewing direction of the viewport
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddSphere()
;; This example creates a sphere in model space.
;; Define the solid sphere
(setq centerPoint (vlax-3d-point 5 5 0)
radius 5)
(setq sphereObj (vla-AddSphere modelSpace centerPoint radius))
;; Change the viewing direction of the viewport
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
GMT+8, 2026-10-29 02:45
