AddShape 方法 (ActiveX)
基于由名称、给定插入点、比例因子和旋转标识的模板创建 Shape 对象。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddShape(Name, InsertionPoint, ScaleFactor, Rotation) 返回值 (RetVal)类型:形状 新创建的对象。Shape 言论在添加 Shape 对象之前,必须使用该方法加载包含所需形状的文件。LoadShapeFile 例子VBA: Sub Example_AddShape()
' This example creates a BAT shape from the ltypeshp.shx file.
' Load the shape file containing the shape you wish to create.
' Note: Replace the ltypeshp.shx file name
' with a valid shape file for your system.
On Error GoTo ERRORHANDLER
ThisDrawing.LoadShapeFile ("C:/Program Files/AutoCAD/Support/ltypeshp.shx")
Dim shapeObj As AcadShape
Dim shapeName As String
Dim scalefactor As Double
Dim rotation As Double
' "diode" is defined in es.shx file
shapeName = "BAT"
insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
scalefactor = 1#
rotation = 0# ' Radians
' Create the diode shape object in model space
Set shapeObj = ThisDrawing.ModelSpace.AddShape(shapeName, insertionPoint, scalefactor, rotation)
Exit Sub
ERRORHANDLER:
MsgBox "Cannot find the shape file.", , "AddShape Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AddShape()
;; This example creates a BAT shape from the ltypeshp.shx file.
;; Load the shape file containing the shape you wish to create.
;; Note: Replace the ltypeshp.shx file name
;; with a valid shape file for your system.
(setq shapeFile ".\\ltypeshp.shx")
(if (/= (findfile shapeFile) nil)
(progn
(vla-LoadShapeFile doc (findfile shapeFile))
;; "diode" is defined in es.shx file
(setq insertionPoint (vlax-3d-point 2 2 0)
shapeName "BAT"
scalefactor 1
rotation 0) ;; Radians
;; Create the diode shape object in model space
(setq shapeObj (vla-AddShape modelSpace shapeName insertionPoint scalefactor rotation))
(alert "Cannot find the shape file.")
GMT+8, 2026-10-26 17:29
