AddSeparator 方法 (ActiveX)
将分隔符添加到现有菜单或工具栏。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddSeparator(Index) 言论菜单或工具栏中的第一项不能是分隔符,因此不能将分隔符添加到索引位置 0。 不能在紧挨着另一个分隔符旁边添加分隔符。 例子VBA: Sub Example_AddSeparator()
' This example creates a new menu called TestMenu and inserts a menu item
' and a separator into it. The menu is then displayed on the menu bar.
' To remove the menu after execution of this macro, use the Customize Menu
' option from the Tools menu.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new menu
Dim newMenu As AcadPopupMenu
Set newMenu = currMenuGroup.Menus.Add("TestMenu")
' Add a menu item to the new menu
Dim newMenuItem As AcadPopupMenuItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
' Add a separator to the end of the menu
Dim newMenuSeparator As AcadPopupMenuItem
Set newMenuSeparator = newMenu.AddSeparator("")
' Display the menu on the menu bar
newMenu.InsertInMenuBar ThisDrawing.Application.MenuBar.count + 1
可视化 LISP: (vl-load-com)
(defun c:Example_AddSeparator()
;; This example creates a new menu called TestMenu and inserts a menu item
;; and a separator into it. The menu is then displayed on the menu bar.
;; To remove the menu after execution of this macro, use the Customize Menu
;; option from the Tools menu.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new menu
(setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
;; Add a menu item to the new menu
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
;; Add a separator to the end of the menu
(setq newMenuSeparator (vla-AddSeparator newMenu ""))
;; Display the menu on the menu bar
(vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
;; Display the menu bar
(vla-SetVariable doc "MENUBAR" 1)
GMT+8, 2026-10-27 22:42
