AddRay 方法 (ActiveX)
创建穿过两个唯一点的光线。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddRay(Point1, Point2) 言论没有其他评论。 例子VBA: Sub Example_AddRay()
' This example creates a ray in model space.
Dim rayObj As AcadRay
Dim basePoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
' Define the ray
basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
SecondPoint(0) = 4#: SecondPoint(1) = 4#: SecondPoint(2) = 0#
' Creates a Ray object in model space
Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddRay()
;; This example creates a ray in model space.
;; Define the ray
(setq basePoint (vlax-3d-point 3 3 0)
secondPoint (vlax-3d-point 4 4 0))
;; Creates a Ray object in model space
(setq rayObj (vla-AddRay modelSpace basePoint secondPoint))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-26 13:37
