AddExtrudedSolidAlongPath 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 997| 评论: 0|原作者: admin|来自: AutoCAD
在给定轮廓和拉伸路径的情况下创建拉伸实体。
RetVal = object.AddExtrudedSolidAlongPath(Profile, Path)
类型:块、模型空间、纸空间
此方法应用到的对象。
轮廓
访问:仅输入
类型: 区域
配置文件只能是对象。Region
路径
访问:仅输入
类型:圆弧、圆形、椭圆、折线、样条
路径只能是 、 、 、 或对象。PolylineCircleEllipseSplineArc
返回值 (RetVal)
类型: 3DSolid
拉伸的对象。3DSolid
只能拉伸 2D 平面区域。
路径不应与轮廓位于同一平面上,也不应具有高曲率区域。
Sub Example_AddExtrudedSolidAlongPath()
    ' This example extrudes a solid from a region
    ' along a path defined by a spline.
    ' The region is created from an arc and a line.
    Dim curves(0 To 1) As AcadEntity
    ' Define the arc
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
    radius = 2#
    startAngle = 0
    endAngle = 3.141592
    Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
    ' Define the line
    Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).startPoint, curves(0).endPoint)
    ' Create the region
    Dim regionObj As Variant
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    ' Define the extrusion path (spline object)
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    ' Define the Spline Object
    startTan(0) = 10: startTan(1) = 10: startTan(2) = 10
    endTan(0) = 10: endTan(1) = 10: endTan(2) = 10
    fitPoints(0) = 0: fitPoints(1) = 10: fitPoints(2) = 10
    fitPoints(0) = 10: fitPoints(1) = 10: fitPoints(2) = 10
    fitPoints(0) = 15: fitPoints(1) = 10: fitPoints(2) = 10
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ' Create the solid
    Dim solidObj As Acad3DSolid
    Set solidObj = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(regionObj(0), splineObj)
    ZoomAll
(defun c:Example_AddExtrudedSolidAlongPath()
    ;; This example extrudes a solid from a region
    ;; along a path defined by a spline.
    ;; The region is created from an arc and a line.
    ;; Define the arc
    (setq centerPoint (vlax-3d-point 5 3 0)
          radius 2
          startAngle 0
          endAngle 3.141592)
    (setq arc (vla-AddArc modelSpace centerPoint radius startAngle endAngle))
    ;; Define the line
    (setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
    (setq curves (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element curves 0 arc)
    (vlax-safearray-put-element curves 1 line)
    ;; Create the region
    ;(setq regionObj (vlax-make-safearray vlax-vbObject '(0 . 0)))
    (setq regionObj (vla-AddRegion modelSpace curves))
    ;; Define the extrusion path (spline object)
    (setq startTan (vlax-3d-point 10 10 10)
          endTan (vlax-3d-point 10 10 10))
    (setq fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 10 10
				                                 10 10 10
				                                 15 10 10
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    ;; Create the solid
    (setq solidObj (vla-AddExtrudedSolidAlongPath modelSpace (vlax-safearray-get-element (vlax-variant-value regionObj) 0) splineObj))
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-28 01:29
