AddDimAligned 方法 (ActiveX)
创建对齐的尺寸对象。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddDimAligned(ExtLine1Point, ExtLine2Point, TextPosition) 言论在对齐尺寸中,尺寸线平行于延伸线原点。延长线原点是使用 和 属性指定的。ExtLine1PointExtLine2Point ![]() 例子VBA: Sub Example_AddDimAligned()
' This example creates an aligned dimension in model space.
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
' Define the dimension
point1(0) = 5#: point1(1) = 5#: point1(2) = 0#
point2(0) = 10#: point2(1) = 5#: point2(2) = 0#
location(0) = 5#: location(1) = 7#: location(2) = 0#
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddDimAligned()
;; This example creates an aligned dimension in model space.
;; Define the dimension
point2 (vlax-3d-point 10 5 0)
(vla-ZoomAll acadObj)
GMT+8, 2026-10-27 19:20
