AddCustomObject 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 965| 评论: 0|原作者: admin|来自: AutoCAD
创建自定义对象。
RetVal = object.AddCustomObject(ClassName)
类型:块、模型空间、纸空间
此方法应用到的对象。
类名
访问:仅输入
类型:字符串
必须在 ObjectARX® 应用程序 (ObjectARX DLL) 中定义 rxClassName,否则该方法将失败。
返回值 (RetVal)
类型:自定义对象
新创建的 Custom 对象。
必须加载定义 rxClassName 定制类的 ObjectARX DLL。在 Application 对象上使用 LoadARX 方法显式加载 ObjectARX 文件。
Sub Example_AddCustomObject()
    ' This example adds a custom object to model space.
    ' Load the ObjectARX application that defines the custom object.
    ' Note: The application listed here does not exist and
    ' will cause an error when run. Change the application name
    ' to the path and name of your ObjectARX Application.
    ThisDrawing.Application.LoadArx "MyARXApp.dll"
    ' Once the application has been loaded successfully,
    ' add the custom object to model space.
    Dim customObj As AcadObject
    Set customObj = ThisDrawing.ModelSpace.AddCustomObject("MyNewObject")
(defun c:Example_AddCustomObject()
    ;; This example adds a custom object to model space.
    ;; Load the ObjectARX application that defines the custom object.
    ;; Note: The application listed here does not exist and
    ;; will cause an error when run. Change the application name
    ;; to the path and name of your ObjectARX Application.
    (vla-LoadArx acadObj "MyARXApp.dll")
    ;; Once the application has been loaded successfully,
    ;; add the custom object to model space.
    (setq customObj (vla-AddCustomObject (vla-get-ModelSpace doc) "MyNewObject"))
GMT+8, 2026-11-11 04:57
